Two Fab / wleding tables, 1 normal size, 1 huge Pictures - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2008, 07:54 PM   #1
JKOZ
yes
JKOZ's Avatar
Default Two Fab / wleding tables, 1 normal size, 1 huge Pictures
The rust you see on these if very light, just from moving to a storage unit. If you want I can arrange them to be sandblasted before picking them up.
First one, 3/8" top plate, heavy duty, perfect for shop or garage $250
33" x 90" top plate 34.5" tall with adjustable screws for leveling.
weighs approx 500lbs
Second one is a 5' x 10' extremely heavy duty table. 3/4" top plate and the angle iron frame work is made of 3/8" thick 3x3" angle. 40" tall to top of table.
The casters are reated for 6000lbs each so you can put almost anything you want on it. The table weights approx 3500lbs. You can actually roll it around pretty good.
Wired with 8 110v outlets and a long extension cord.
Bottom shelf is fully plated and upper shfl is expanded metal.
$1200, non negotiable. You couldn't buy the steel for that price, the casters would cost you around $500 each.
JKOZ is offline   Reply With Quote
Old February 17th, 2008, 08:01 PM   #2
PavementPounder
PavementPounder's Avatar
Is that second one the table you had the entire Blazer sitting on in the old shop?
Old February 17th, 2008, 09:26 PM   #3
JKOZ
yes
JKOZ's Avatar
sure is. I figured it was a long shot in selling that table on here. I may try ebay once and if it doesn't sell i'll just hold onto it. One of those things that I could use------sometime.
Page generated in 0.22829 seconds with 32 queries
