chevy 10 bolt front axle! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2008, 05:42 PM   #1
dodgeboy
redneck truck club
dodgeboy's Avatar
Default chevy 10 bolt front axle!
i have a friend with a 79 3/4 chevy drivetrain welded the front 10 bolt together and yea it broke the shafts. so i got him a axle from a 87 3/4 sub its a 10 bolt but the ujoint for a 79 is way bigger than a 87 will the carrier and shafts still work?? i was told about a cut off in 85 or 86 ish.. trying to get together before the 23rd anything would help parts or info!!!
thanks
dodgeboy is offline   Reply With Quote
Old February 17th, 2008, 08:08 PM   #2
PavementPounder
PavementPounder's Avatar
Are you sure your buddy's busted axle is a 10-bolt? I thought 1979 was the last year for the D44 front?
Old February 18th, 2008, 06:32 PM   #3
dodgeboy
redneck truck club
dodgeboy's Avatar
when we ordered the 5:13 gears thats what they told us it was a corp. 8.5
Old February 19th, 2008, 06:54 PM   #4
PavementPounder
Who is "they" and were "they" on the other end of the phone, or did "they" see the axle in person?
Old February 19th, 2008, 07:40 PM   #5
dodgeboy
redneck truck club
dodgeboy's Avatar
they are the people that seen the axle and sold us the gears that where installed and worked great until it was taken back apart. thats when the welding tookpart, the rest was history when it got put in 4wd
Old February 20th, 2008, 08:55 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
I know the axle i gave ya uses 0297 series joints, cause that what i used in the stubs.
Old February 27th, 2008, 02:38 PM   #7
larboc
Pirate of Dollar Bay.1TBB
Are we talking about wheel u-joints, or the pinion u-joint.
larboc is offline   Reply With Quote
Old February 27th, 2008, 06:17 PM   #8
dodgeboy
redneck truck club
dodgeboy's Avatar
the wheel joint!
Old February 27th, 2008, 11:36 PM   #9
larboc
Something isn't making sense. You sure it's a different size? no chance it is either a 60, or out of a non-GM vehicle? Dodge possibly?
Old February 29th, 2008, 06:44 PM   #10
dodgeboy
redneck truck club
dodgeboy's Avatar
the wheel joint from the 79 is bigger than the wheel joint for the 87. so if i was to get stub shafts for the 87 and run the small wheel joint will the splines be the same for his lock outs or will i have to get hubs too???
Old March 5th, 2008, 03:36 PM   #11
bigblazer
ditch digger
You've got somthing wrong, some where. Dana 44 and 10 bolts have use the same joint since '73 in chevys at least. The newer spicer part # 760 somthing. If what you have is the different then what was in it, find another shaft.
bigblazer is offline   Reply With Quote
Page generated in 0.30210 seconds with 56 queries
