Autobody and Mechanic Services (Clawson) - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Support your local GL4x4 member owned business
Old April 11th, 2013, 10:07 PM   #61
firehawk
Live Action!
firehawk's Avatar
Just painted another one for a member here. Thanks!
Need any work done on your car?
Mechanical or body or whatever!
I am currently redoing my Dads master bathroom so I do home repairs too.
Old June 29th, 2014, 12:20 AM   #62
ramiromunoz
I have some cement splattered onto the passenger dor of my suv. Incan send a pic and I would like to know how much a job like this will run.... Thanks. Ramiro
Sent from my HTC One_M8 using Tapatalk
ramiromunoz is offline   Reply With Quote
Old January 14th, 2015, 02:31 PM   #63
BooGTS
Boost Withdrawl
BooGTS's Avatar
Pmed you
BooGTS is offline   Reply With Quote
Old March 8th, 2015, 10:22 PM   #64
Leanz
Full taste of tender
Leanz's Avatar
Hey, I need my body work finished and my jeep painted this spring, are you still up for the job?
Leanz is offline   Reply With Quote
Old May 28th, 2015, 08:00 AM   #65
firehawk
Live Action!
firehawk's Avatar
Open for business
Old June 2nd, 2015, 05:16 PM   #66
muddinman56
blood,sweat and beers
muddinman56's Avatar
Fix rust?
Old June 2nd, 2015, 07:56 PM   #67
robrocketanski
Would you be interested in this? I know pics won't work but I can get the truck n Ferndale sometime if you can give some guess on cost and a description of how you would repair it.
2014 Silverado
The rocker is damaged as shown and there is a wind noise after.
ID:	172297   Click image for larger version
robrocketanski is offline   Reply With Quote
Old June 2nd, 2015, 08:00 PM   #68
firehawk
Live Action!
firehawk's Avatar
Originally Posted by muddinman56 View Post
Fix rust?
Sure do. Anything automotive and beyo. .
Been fixing dump trailers, cracks and rust.
2014 Silverado
Absolutely. Bring it by for an estimate. I can give a rough quote from the pic later
Old June 2nd, 2015, 08:02 PM   #69
firehawk
Live Action!
firehawk's Avatar
Im fixing my trailer now. Crashed the fender into something that didn't move and got sidetracked on building a metal break.
ID:	172313   Click image for larger version
ID:	172321   Click image for larger version
ID:	172329   Click image for larger version
Old June 2nd, 2015, 09:17 PM   #70
firehawk
Live Action!
firehawk's Avatar
Bent 1/8" diamond plate
10.5" wide
Old June 2nd, 2015, 10:47 PM   #71
1 ton tj on 40's
1 ton tj on 40's's Avatar
dam what cant you rig up. I will have to remember this one.
Old June 2nd, 2015, 11:48 PM   #72
firehawk
Live Action!
firehawk's Avatar
Did you get it done yet?
Old June 2nd, 2015, 11:53 PM   #73
firehawk
Live Action!
firehawk's Avatar
I started it years ago but actually needed it so out of necessity i finished it .
Going to make a top hold down to go all the way across. I think it has 42" capacity for thinner sheet metal. Still need to do some bracing and gussets to get the flex out of it. I lifted the whole cart off the ground bending that piece and there is a 14bolt housing under the welding blankets.
Old June 3rd, 2015, 12:02 PM   #74
muddinman56
I just need cab corners and rockers on a 2004 silverado single cab inners are fine
Old June 3rd, 2015, 12:56 PM   #75
firehawk
Live Action!
firehawk's Avatar
Rockers are about $1200
Cab corners add $400
I will be doing mine this summer too
Old June 3rd, 2015, 08:45 PM   #76
firehawk
Live Action!
firehawk's Avatar
Trailer almost done.
ID:	172657   Click image for larger version
ID:	172665   Click image for larger version
Old June 3rd, 2015, 08:48 PM   #77
firehawk
Live Action!
firehawk's Avatar
One of the other trailers I fixed, rusty structure replaced
ID:	172681   Click image for larger version
ID:	172689   Click image for larger version
Old June 4th, 2015, 04:17 PM   #78
firehawk
Live Action!
firehawk's Avatar
Half painted trailer. And that's all its gettin this week.
ID:	172929   Click image for larger version
Old June 4th, 2015, 05:34 PM   #79
1 ton tj on 40's
Yep that red.
Old June 5th, 2015, 12:49 PM   #80
firehawk
Live Action!
firehawk's Avatar
Yep that red.
Yea its bright. I like it.
Page generated in 0.32683 seconds with 84 queries
