14 bolt width - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2008, 10:31 PM   #1
Badphish
Default 14 bolt width
I have a 14 bolt out of an 80's chevy 3/4 ton and am wondering what the width is flange to flange as it is in storage some distance away.
Badphish is offline   Reply With Quote
Old February 16th, 2008, 11:20 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
depends on what it is out of.
single rear wheel, dually 67 inch
cab and chassis 63 inches
so probally looking at 67
Old February 17th, 2008, 10:07 AM   #3
Badphish
yes it was single rear wheel anks
Old February 17th, 2008, 09:05 PM   #4
PavementPounder
PavementPounder's Avatar
They both have the same WMS? The one in my Suburban seems narrower than that visually.
Old February 17th, 2008, 09:16 PM   #5
hosejockey4506
Visiting Admin
my info is according to billa vista and his 14 bolt bible. i found it to be wierd that they were the same.
Old February 17th, 2008, 09:27 PM   #6
PavementPounder
I see the part you read. Scroll down a little farther from that and look at the chart. I think what you posted was just a typographical error by him that never got corrected.
http://www.pirate4x4.com/tech/billav...ble/index.html
SRW = 67.5"
DRW = 72"
C&C = 63.5"
Van = 70"
Old February 17th, 2008, 10:17 PM   #7
Tab
Tab's Avatar
I just built one from a 99 old body style one ton single rear wheel and after converting to discs it comes out to 65.25 wms to wms. Not sure why and have never seen one like that. The hubs look to be somewhere between c&c and the normal single wheel. The only difference was the newer ones have a serviceable brake drum that comes off over the studs as opposed to having to press out the studs to get them off. But yes, yours should be 67".
Old February 18th, 2008, 06:47 PM   #8
BMFmike
meh.
BMFmike's Avatar
I keep reading the 14 bolt bible and I cant find an exact answer, how much width do you take off by changing single wheel hubs with C&C/Dually?
Old February 18th, 2008, 09:35 PM   #9
Tab
Tab's Avatar
from 67 to 63. so 4 I believe
Old February 19th, 2008, 12:18 PM   #10
BMFmike
meh.
BMFmike's Avatar
Would it really be that much? Essentially you would take a SRW and put the same hubs on it that a C&C uses, but the backing plates are not in the same place.
I just need to find some hubs and find out.
Old February 19th, 2008, 07:34 PM   #11
Tab
Tab's Avatar
your only tlking 2 inches per side. yes, the hubs are that different. look at the 14b bible on pirate and they show a side by side pic of the two hubs.
Page generated in 0.22324 seconds with 56 queries
