Pinion Angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2008, 07:40 PM   #1
ddeadserious
ddeadserious's Avatar
Default Pinion Angle
This is for me putting my 8.8 into my XJ.
I have a SYE/CV Driveshaft.
I know the pinion should point directly at the t-case, but I've also read that it should be a certain degree up or down to account for axle wrap..
So what is it? Straight at the t-case or slightly up/down?
ddeadserious is offline   Reply With Quote
Old February 16th, 2008, 07:46 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
down 2 degrees is what I hear a lot.
Old February 16th, 2008, 08:31 PM   #3
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Straight Would be perfect but you but it down a couple degrees to keep the ujoints in service longer.
tcxtreme1000 is offline   Reply With Quote
Old February 16th, 2008, 10:22 PM   #4
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i have always been told 2 degrees under pointing straight at it and the reason is not for u joint life which makes sense but that way under load the spring wrap lines it up to be straight.
Old February 16th, 2008, 11:39 PM   #5
Jsawduste
Jsawduste's Avatar
This is correct. The torque loads will twist the center ever so slighty within the spring. The 2 degrees down will help to cancel that out.
Jsawduste is offline   Reply With Quote
Old February 17th, 2008, 08:22 AM   #6
I've done it both ways. Can't say that I've seen a difference in u-joint life. I kinda look at it this way. If you are straight, 2 degrees above isn't going to hurt you under load if your suspension limits you to that. On the other hand highway driving is not putting enough load on your suspension to twist it. Therefore, you are running down the road 2 degrees below, which may cause slight vibrations and hurt the long term life of the joint.
I think it can be argued both ways.
Page generated in 0.23731 seconds with 41 queries
