Chevy front axle center section question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2006, 12:19 AM   #1
greenjeep
greenjeep's Avatar
Default Chevy front axle center section question
Has anyone on here ever rebuilt the front axle on a 1/2 ton 88 up truck? Mine is noisy, it had some water in it. I think some new bearings and it will be all good.
I have rebuilt lots of different solid front and rear axles before. I am just a little unsure about having case halfs to deal with.
any input would be great.
thanks,
Fred
greenjeep is offline   Reply With Quote
Old March 25th, 2006, 07:53 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
there not bad to do, you have to use anarobic sealer between the cases after you set up your new bearings & gears. the old ones like yours tend to loose ring gear bolts, I have repaired a few where the bolts came out through the side of the case.
Yetti
Old March 25th, 2006, 10:31 AM   #3
greenjeep
greenjeep's Avatar
Thanks for the reply.
So to do a pattern check you reassemble it, spin it a couple times, then disassemble? Do they use shims, or spanner nuts for adjustments. Any special tools sepcific to this type of axle? I acually have a 94 1/2 Suburban.
Also do you know when they switched the actuators for the axles(thermal to mechanical)?
Old March 25th, 2006, 11:30 AM   #4
Yetti
Yetti's Avatar
here this should help...
Yetti
Old March 25th, 2006, 03:41 PM   #5
greenjeep
greenjeep's Avatar
yes it does, thanks
Old March 26th, 2006, 12:14 AM   #6
Symmes
A sugestion too. My friend has a 94 3/4 suburban and it engaged really slow. So he upgraded to a acuator and wiring harness to a later year model. It is totally different now, works a lot better. If you want more info i can get it if ur interested. thanks
jake
Symmes is offline   Reply With Quote
Page generated in 0.18764 seconds with 41 queries
