Thermite - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2006, 09:28 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default Thermite
http://www.lemonzoo.com/content/M/14819-content.wmv
That is all you need to know... 14 meg DL
Revenge on french engineering
Old March 24th, 2006, 09:45 PM   #2
junk90xj
ALLPRO AUTO
junk90xj's Avatar
sweet i need some of that stuff
http://www.apalansing.com/
Old March 24th, 2006, 09:52 PM   #3
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
That was AMAZING!!!
Old March 24th, 2006, 09:56 PM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Made some last summer....you can get everything you need to make it off e-bay. Lit it off on Elberta Beach. It rocked!
Old March 24th, 2006, 10:05 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
Default Heh Heh
I want some!
Old March 24th, 2006, 10:07 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Maybe this summer we'll do it again...just don't know where to do it around here without either getting in trouble or setting half the city on fire.
Old March 24th, 2006, 10:11 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
Default Well?
I have a beach.. you have thermite....Huh huh?
Old March 25th, 2006, 12:36 PM   #8
rallyemore
Snowman
rallyemore's Avatar
Send a message via AIM to rallyemore
yeah, I've made thermite before. (thank you anarchists cookbook)
Just FYI,
Thermite is nasty shit. Here is a good and easy way to make it.
The first step is to get some iron-oxide (which is RUST!). Here is
a good way to make large quantities in a short time:
- Get a DC convertor like the one used on a train set. Cut the
connector off, seperate the wires, and strip them both.
- Now you need a jar of water with a tablespoon or so of sodium
chloride (which is SALT!) added to it. This makes the water
conductive.
- Now insert both wires into the mixture (I am assuming you
plugged the convertor in...) and let them sit for five minutes.
One of them will start bubbling more than the other. This is the
POSITIVE(+) wire. If you do not do this test right, the final
product will be the opposite (chemically) of rust, which is RUST
ACID. You have no use for this here (although it IS useful!).
- Anyway, put the nail tied to the positive wire into the jar. Now
put the negative wire in the other end. Now let it sit overnight
and in the morning scrape the rust off of the nail & repeat until
you got a bunch of rust on the bottom of the glass. Be generous
with your rust collection. If you are going through the trouble of
making thermite, you might as well make a lot, right?
- Now remove the excess water and pour the crusty solution onto a
cookie sheet. Dry it in the sun for a few hours, or inside
overnight. It should be an orange-brown color (although I have
seen it in many different colors! Sometimes the color gets fucked
up, what can I say... but it is still iron oxide!)
- Crush the rust into a fine powder and heat it in a cast-iron pot
until it is red. Now mix the pure iron oxide with pure alluminum
filinos which can be bought or filed down by hand from an aluminum
tube or bar. The ratio or iron oxide to aluminum is 8 grams to 3
grams.
- Congrats! You have just made THERMITE! Now, to light it...
- Thermite requires a LOT of heat (more than a blow torch!) to
ignite. However, a magnesium ribbon (which is sorta hard to find..
call around) will do the trick. It takes the heat from the
burning magnesium to light the thermite.
- Now when you see your victim's car, pour a fifty-cent sized pile
onto his hood, stick the ribbon in it, and light the ribbon with
the blow torch. Now chuckle as you watch it burn through the hood,
the block, the axle, and the pavement. BE CAREFUL! The ideal
mixtures can vaporize CARBON STEEL! Another idea is to use
thermite to get into pay phone cash boxes. HAVE FUN!!
rallyemore is offline   Reply With Quote
Old March 25th, 2006, 05:34 PM   #9
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
Someone should make some for the pig gig....
Spence1986 is offline   Reply With Quote
Old March 25th, 2006, 05:39 PM   #10
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
im pretty sure this stuff is close to cad welding powder. it can be bought or ordered from most electrical supply houses.
Old March 25th, 2006, 05:46 PM   #11
going-strong
'96 360 sport 4x4
going-strong's Avatar
that was awsome
going-strong is offline   Reply With Quote
Old March 25th, 2006, 07:50 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
All that "put a nail in water and scrape some rust off in the morning" stuff takes too long. You can get both parts seperatly ready to use off ebay.
Iron Oxide
powdered Aluminum
Old March 26th, 2006, 01:59 PM   #13
rallyemore
Snowman
rallyemore's Avatar
Iron Oxide
powdered Aluminum
Well there you go!
Old March 26th, 2006, 02:15 PM   #14
clarkstoncracker
lol
clarkstoncracker's Avatar
that is from my most favorite show on cable tv. brainiac
I love british television
Old March 26th, 2006, 06:14 PM   #15
esl_cherokee
esl_cherokee's Avatar
here is a link to buy it already made in case you dont want to make it. almost at bottom of page everything is in alphabetical order.
http://www.unitednuclear.com/chem.htm
esl_cherokee is offline   Reply With Quote
Old March 26th, 2006, 06:43 PM   #16
Has some interesting applications... one thing I've seen done, is to join iron rails (like railroad tracks) into seamless pieces..
The leave a gab between the rail ends, place a mold around it, and put a pot of that stuff on top. It fills the mold, and when its cool, its one seamless rail..
Old March 27th, 2006, 12:25 AM   #17
Saurian
Iron Chef!!!
Saurian's Avatar
Hmm... The end result is molten iron, I imagine you could very quickly cast most anything if you had the molds made...
Saurian is offline   Reply With Quote
Page generated in 0.30344 seconds with 73 queries
