Smoke Wrench - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: What brand and model
Victor 11 52.38%
Harris 6 28.57%
Henrob / Cobra 2000 0 0%
Smith 0 0%
Meco Midget 0 0%
Harbor freight special 3 14.29%
other 1 4.76%
Multiple Choice Poll. Voters: 21. You may not vote on this poll
Old February 15th, 2008, 07:58 AM   #1
JeepInABox
In too deep
JeepInABox's Avatar
Default Smoke Wrench
I have the small tanks for a oxy/ace torch.
Looking for a setup to do a little of every thing from cutting inch to gas welding.
Who has what and the pros and cons?
Old February 15th, 2008, 09:42 AM   #2
95geo
newbie
95geo's Avatar
plasma for cutting and mig for welding. I have a torch but I have no idea what brand it is... just use it for heating things up.
Old February 15th, 2008, 10:37 AM   #3
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I have the Harbor freight small setup for like 4 years now. I fubar'd the acetylene pressure guage and it reads 5 psi too high. have yet to replace it I just compensate for it.
works great tho. I have cut 1/4 inch with it just fine. mostly I use for heating tho. works great and my local welding supply said all the fittings and gauges are of standard design and easily replaced if need be. just remember you exchange your acetylene tank each time.
Old February 15th, 2008, 11:22 AM   #4
I have the small set from TSC. Don't know the brand. They work quite well for most garage projects and are small enough to keep in the trailer when on the road.
Old February 15th, 2008, 01:06 PM   #5
x2
They are good for heating and rough cutting.
Old February 15th, 2008, 07:02 PM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
x2
x's 3
Mine are Harris. I have had them for almost 20 years. I used them a ton until I got the plasma cutter. Now like mentioned they are used for general heating and quick no care cuts.
Old February 18th, 2008, 02:17 AM   #7
incogrhino
i pull out
incogrhino's Avatar
Victor running on propane.Use it for heating/bending and cutting.Works good and can get fuel 24/7.
incogrhino is offline   Reply With Quote
Old February 18th, 2008, 12:55 PM   #8
JeepInABox
In too deep
JeepInABox's Avatar
Thanks for the input, are there any special adapters i will need to get full size gauges to use with these small tanks or is it a standard thread?
Page generated in 0.18903 seconds with 48 queries
