Looking for cheap locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2008, 09:57 PM   #1
88WRANGLERYJ
jeeper
88WRANGLERYJ's Avatar
Default Looking for cheap locker
Blew the spiders in my dana 35 looking to put a locker back there but im on quite the budget so i was wondering what you guys think is a better the powertrax lock right or the detroit EZ locker? or maybe even mini spool but its still my DD. So looking for the more streetable option and welding it is out of the question.
88WRANGLERYJ is offline   Reply With Quote
Old February 13th, 2008, 11:23 PM   #2
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
Aussie or lockrite are the cheapest, Aussie is a little cheaper but supposed to be a little better then the lockrite.
71jeepster is offline   Reply With Quote
Old February 13th, 2008, 11:42 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
If you're going to use it for more DD than wheeling, I'd go with the Powertrax No Slip/No-Spin. It's one of the two. It's a mechanical locker very similar to a Detroit, but there isn't the annoying ratcheting sound when going around a corner. It takes a little getting used to trying to make a quick turn from a dead stop when getting into the throttle hard, but the Powertrax has virtually no noise when driving around. You will feel it engage/disengage when you get on/off the throttle.
Old February 14th, 2008, 08:06 AM   #4
jeeptjpaul
jeeptjpaul's Avatar
There is no mini spool for a dana 35. The lock rite and ez locker are virtually the same. The no slip is nice, but not really worth the extra money. I never found the ratcheting sound from my lock rite annoying. In fact, I had to pay attention to even hear it. I would put a lock rite in it. It is less expensive than the no slip and will accomplish the same thing.
jeeptjpaul is offline   Reply With Quote
Old February 14th, 2008, 08:21 AM   #5
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
i have lock right lockers in front and rear in my dd, on pavement can bearly tell there there and i can never here them
Old February 14th, 2008, 08:25 AM   #6
Jeepster20
Guest
Posts: n/a
I just got one of the lock right lockers from power trax. I bought if just that reason I know someone here that had one and you could not hear it at all and it still got the job done very well i might add.
Old February 15th, 2008, 11:43 PM   #7
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
ttocsnekia is offline   Reply With Quote
Old February 16th, 2008, 02:57 AM   #8
landrollover
landrollover's Avatar
Send a message via AIM to landrollover
Ive seen the best reliabilty out of the aussies. They are somewhat loud but work great. A lunch box locker will only work as good as the install.
landrollover is offline   Reply With Quote
Old February 16th, 2008, 09:01 AM   #9
BRUSER
BRUSER's Avatar
Go for the aussie... I installed one in a Yj and it worked sweet. If I can install something and have it work, it's got to be a no brainer!
BRUSER is offline   Reply With Quote
Old February 16th, 2008, 09:23 AM   #10
95geo
newbie
95geo's Avatar
I'm a little confused here, what do you mean? it's not like setting up a ring and pinion where you have adjustments and styles of patterns for the wheeling you do. there is a box of parts and you put them in the carrier in the correct order and thats it........
Old February 16th, 2008, 02:51 PM   #11
zjkid
zjkid's Avatar
I think he means having the correct clearances.
But I would recommend an aussie.
zjkid is offline   Reply With Quote
Old February 16th, 2008, 03:13 PM   #12
sodapop
Support the Sport!
sodapop's Avatar
Well there's no such thing as a cheap locker for a Dana 35. See the problem isn't the locker cost, it's the associated damage from the weak axle after the locker is installed. I blew my first dana 35 (open) up with 29" tires on the street with a 4 cyl.- 7 teeth off the ring and pinion.
if you end up putting one in, I'd get an Aussie. I've got 2 and am very happy with them both. Everybody I know that has an ez locker (3 people) has had them break.
Old February 17th, 2008, 08:25 AM   #13
I had no problems with lock-rites. When I blew my D35, it was under alot of load with 300hp and 35's. Split the carrier right in half, broke a bearing race, took out the r&p and the end of an axle shaft.
There was no damage to the locker other than it needed new springs.:tonka:
Page generated in 0.31040 seconds with 62 queries
