my little jeep restoration/build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2008, 12:05 AM   #1
VTJeepCJ84
Send a message via AIM to VTJeepCJ84 Send a message via Skype™ to VTJeepCJ84
Default my little jeep restoration/build
I've been lurking here for a while, figured I'd be nice and post up my junk for those who haven't seen my build on other forums. I've been doing a lot of the work on the Terquoise Tartcart, which has consumed a lot of time resently.
This was what I did last winter/spring between mid Jan, and mid May. I'll add to this as I continue the much needed front axle update and a little more tube work.
OK, here's where I started.
Step one: Get "real" job. Check
Step two: Buy garage that happens to come with a house. Check
Step three: tear shit apart. awww shit here we go.
Starting with this:
[/img]
back on poker run 2005:
the work space, 24x24 is sooo not big enough:
Step 4: Have a plan: New frame, and cage. Swap the beat T-156 for a TH400, tweek the rear 4 link. lower body by removing body mounts. Piece of cake.
Box section is 2x3" 1/8 wall.
on the last trip out with Sean(driving Chris' jeep) I let James pull out Sean, this was the result. DOH.
Tweeked rear suspension. 0-1* Roll Axis, 96%anti-squat.
So now it's the weekend before carni. Time to test fit the old body on the new frame.
No pictures of it, but inorder to fit the body down on the frame, and clear the suspension and clocked t-case, 3/4 of the floor would have to be cut out. Shit
Step 5? ah fukc the steps everything was thrown out the window here. After some QT up in Houghton it was officially decided Tube Buggy here I come. Now the fun begins :mrgreen: Oh yeah did I mention that we were planning to go back to Moab in the first of May?
So there I was, at the Toyota dealership, FUCK. It's only money. This followed me home:
Ok back to the build. Tube Buggy: Therefore new toys were required.
Trying to figure out WTF i'm doing. Tubing is all 1.75 .120 wall and 1.5 .120 wall tube. A larger diameter 1.5" die would have been nice especially for doing grill hoops.
Start of the rear frame section:
time to clean the garage, out she goes.
Bling Bling, it's expensive, but so far definately worth it. Funds and time permitting I'd like to get some dyno time sometime to really tune it in right.
Trans cooler and battery in their new homes.
Starting to look like something again.
New steering box bracket, because we all know the stock Jeep ones SUCK. and with the new pitman i had to take the 5* or whatever it was out of the bracket.
Link crossmember, trans mount. working good so far.
Trans parts, WTF no instructions?
Trans case cleaned and painted, got it all back and works like a champ. B&M rebuild kit, Hughes pump, TC, auto/manual valve body.
Starting the sheet metal.
So much easier to finish welding like this.
Ready for paint.
Owww, shinny!
A litte more bling. To date only had to use it to pull Matt's ass out.
VTJeepCJ84 is offline   Reply With Quote
Old February 13th, 2008, 12:06 AM   #2
VTJeepCJ84
She LIVES!
Getting closer.
New trans pan. Blue Torch Fab kit, it does require some alterations as it does not have the notches and kickouts for the valve body, but no complaints about it.
AWWW SHIT! After starting it in gear and the throttle being stuck at WOT and hitting the house this is the results
Well, I had wanted to upgrade axles, guess nows the time, it would have cost me about $350 to get going again with another AMC 20.
Out with the old in with the new. Enter a junkyard 9" that by all the normal markings logically should have been a 31 spline, nope 28. 28 spline 9" is going to be weaker than my chromo'd 29 spline AMC 20. Cost of new chromo shafts is pretty much the same regaurdless of the spline count. Enter the 35 spline Moser shafts. Only real added cost of the 35 spline shafts was the new third member with big bearings.
Did a litte trussing on the stock housing. Basically copied TinyCar on Pirate for the truss.
The next weekI got rear ended at a stop light on bike #1, Honda 599.
Utah was canceled, and i was able to relax a little but finally got her out. Here it is at the Cliff's Insane Terrain Park in IL.
Just a little muddy, took 2 different tries with the pressure washer to get it clean, this is why I'm not a fan of mud.
The new bike so I could bring it up to Houghton for my vacation for the 4th.
Poser shot on the ramp, could have gone a little farther, but Nida's truck was there and we didn't want to move the ramp more.
On some private land in IL.
The final wheelbase is 100" stretched about 2" up front and the rest out back. I there is between 19 and 20" of clearance under the jeep at trail pressure(8-10psi).
I'm currently in So Cal for work so I'm getting delayed in getting the new front axle done. It's going to be a spidertrax housing and knuckles, True Hi9.
Here's how she sits right now on the new rubber, 42" Irok's:
Old February 13th, 2008, 12:40 AM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
one of the better builds I have seen on this site
Old February 13th, 2008, 01:04 AM   #4
ddeadserious
ddeadserious's Avatar
Seriously nice work and good documentation. Keep it up.
ddeadserious is offline   Reply With Quote
Old February 13th, 2008, 01:13 AM   #5
SBC YJ
Heavy Chevy
SBC YJ's Avatar
i just saw this on m-tech forum a few days ago...still f-ing sweet!!!
SBC YJ is offline   Reply With Quote
Old February 13th, 2008, 02:07 AM   #6
incogrhino
i pull out
incogrhino's Avatar
me like
incogrhino is offline   Reply With Quote
Old February 13th, 2008, 09:29 AM   #7
tweak
Are we there yet?
tweak's Avatar
Nice work! I love seeing your garage change though the pics. The bench is clean when you start and half way through it is piled with parts.
Old February 13th, 2008, 11:23 AM   #8
Nice build!
Old February 13th, 2008, 03:17 PM   #9
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
extremely nice!!
Old February 13th, 2008, 03:24 PM   #10
zanderman90
MTU here I come.
zanderman90's Avatar
Sweet build. I saw this ahwile ago on mtu fourwheelers web site.
zanderman90 is offline   Reply With Quote
Old February 13th, 2008, 03:38 PM   #11
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
WOW!!! very nice work. you get 2 gold stars
I'm the man in White.
Old February 13th, 2008, 03:47 PM   #12
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
X2
VERY SWEET, THINK I SEEN IT ON PIRATE?
RIP FULLSIZE4LIFE
Old February 13th, 2008, 05:04 PM   #13
VTJeepCJ84
Originally Posted by SHARPMACHINE View Post
X2
yep you could have seen it there, I posted there a month or 2 ago as well.
I'll probably keep this one a updated more than the one on pirate while I go through the next phase of the build process.
Old February 13th, 2008, 05:15 PM   #14
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
VERY nice
broncobuddha is offline   Reply With Quote
Old February 13th, 2008, 10:59 PM   #15
FQXehhhh
FQXehhhh's Avatar
interested in adoption?
FQXehhhh is offline   Reply With Quote
Old February 13th, 2008, 11:15 PM   #16
cj7on44's
cj7on44's's Avatar
that is sweet
cj7on44's is offline   Reply With Quote
Old February 13th, 2008, 11:39 PM   #17
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Nice work! Got to get me a bender one of these days.. and a bigger garage.
One Arm Steve is offline   Reply With Quote
Old February 14th, 2008, 12:48 AM   #18
VTJeepCJ84
be fore warned, when you get a bender you'll have lots of new friends. I've done 2 sets of front cage bars for YJ's and a few parts for a dirt track car with more to come.
my garage isn't big enough, with just 1 rig in there it's not bad, but put a second in and it gets tight quick.
Old February 14th, 2008, 12:53 AM   #19
SBC YJ
Heavy Chevy
SBC YJ's Avatar
want to do another???
Old February 14th, 2008, 07:13 AM   #20
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
that's sweet!!
71jeepster is offline   Reply With Quote
Page generated in 0.39769 seconds with 83 queries
