welded rear end on DD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2008, 05:11 PM   #1
jeepyj93
Sundowner
jeepyj93's Avatar
Default welded rear end on DD
Does anyone run a welded diff on a daily driver? If you do, or have, how do you like it, and what don't you like about it. Does anyone notice a whole lot more tire wear than with a locker? Any help would be greatly appreciated
jeepyj93 is offline   Reply With Quote
Old February 11th, 2008, 07:11 PM   #2
Bishop
Bishop's Avatar
dont do it
Old February 11th, 2008, 07:49 PM   #3
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Originally Posted by wrifrocks2005 View Post
dont do it
x2 Search, as well. This is covered regularly.
Craig
Old February 11th, 2008, 08:17 PM   #4
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
dont even think about it or ill slap you with a fish.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old February 11th, 2008, 08:18 PM   #5
steveo
In the band!
i welded my 35, and it works great.
Old February 11th, 2008, 08:20 PM   #6
Bishop
Bishop's Avatar
is it youre DD?
Old February 11th, 2008, 08:25 PM   #7
steveo
In the band!
is it youre DD?
yes
Old February 11th, 2008, 08:27 PM   #8
Bishop
Bishop's Avatar
yes
awesome, do you like it? and why not just go with well anything ealse?
Old February 11th, 2008, 08:32 PM   #9
steveo
In the band!
i love it, never had any problems. why would i need something else?
Old February 11th, 2008, 10:14 PM   #10
Bishop
Bishop's Avatar
well its fine if you like it and all, it just seems that for a DD its a little over kill and a pain in the ass
Old February 11th, 2008, 10:28 PM   #11
Cooter21
Im Rick James Bitch
Cooter21's Avatar
Why the Duke Boys did. and they jumped the shit out of there DD.
Cooter21 is offline   Reply With Quote
Old February 12th, 2008, 10:54 AM   #12
bigblazer
ditch digger
It depends on which rear end your running, and how hardcore you are. I've ran 3 dd's with welded rears. If you do a lot of city driving I would save up for a locker. I wouldn't weld a semi floater (dana 35, 44, 10 bolt, ect) in a dd just for the fact that if you break a shaft you don't want your tire to jump ship. If you've got a full floater (14 bolt, dana 60,70) and dont mind the extra tire wear, its a good cheap alternative. But both rear wheels are ALWAYS turning together.
bigblazer is offline   Reply With Quote
Old February 12th, 2008, 05:54 PM   #13
kkodet
kkodet's Avatar
33s and welded in the back of my samurai, can barely tell it is. I'd DD a welded axle over a locked one any day. At least welded ones are real predictable in the corners.
Old February 13th, 2008, 01:32 PM   #14
smasheromalley
smasheromalley's Avatar
x2
the key here is predictability especially if u have a manual trans. You pretty much always konw what a weld locked rear is gonna do, ratchet locker not so much
** to add, the two times Ive seen an axle break while on the STREET were both using lock-rite style ratcheting lockers
Old February 13th, 2008, 02:08 PM   #15
fsumotorhead
N8KVB
fsumotorhead's Avatar
Just weld it already...don't be a pussy.
Old February 13th, 2008, 02:40 PM   #16
jeepyj93
Sundowner
jeepyj93's Avatar
Talking
I found a pretty good deal on an explorer 8.8" that is welded. I am pretty sure that i am going to go in that direction, at least for now. Thanks for the help
Old February 15th, 2008, 11:44 PM   #17
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Never had a problem
ttocsnekia is offline   Reply With Quote
Old February 25th, 2008, 10:38 PM   #18
jeepyj93
Sundowner
jeepyj93's Avatar
How much more accelerated is the tire wear with a spool/welded, than a locker?
Old February 25th, 2008, 11:05 PM   #19
busyfixin
Balls Deep
busyfixin's Avatar
ive put many miles on welded rears. ive never had any issues. it might be a little hairy in a real short wheelbase in the winter. i loved the welded 35 in my shortbox commanche, always predictable, always had traction. it also no longer broke spiders all the time. once you drive a locked rear end for a while, you will notice that a very large portion of your turns will be upon acceleration, when a locker is locked. the only time a locker really helps is if you coast through turns. your not supposed to coast through turns anyway, you are supposed to be slowed down and accelerate through the corner, rendering your locker useless anyway. weld it, you can always put a limited slip in later if you dont like it.
busyfixin is online now   Reply With Quote
Old February 26th, 2008, 12:18 AM   #20
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Depends on your tires.
I ran a welded rear for a few weeks with 33 AT's. It was retarded loud in tight turns. My 36' SX's don't make much noise with a weldeded rear.
JcrOffroad
Zoom Zoom!
Page generated in 0.47686 seconds with 83 queries
