78-79 hp dana 60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2008, 06:57 PM   #1
chevytruckbeing
Default 78-79 hp dana 60
is this a 30 or 35 spline carrier and is t reverse or stands cut gears?
chevytruckbeing is offline   Reply With Quote
Old February 10th, 2008, 07:09 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
35 spline, reverse
Old February 10th, 2008, 07:11 PM   #3
chevytruckbeing
thank you
Old February 10th, 2008, 10:18 PM   #4
chevytruckbeing
ok another problem. it seems that on 4wheel parts dont have a detroit locker for the front to fit 513 gears. can i order 513 thick gears to fit on my 410 rear carrier and just order a 410 carrier for the front?
Old February 10th, 2008, 10:34 PM   #5
chevytruckbeing
bump to keep up since no one looks in this forum hardly
Old February 11th, 2008, 06:13 AM   #6
PavementPounder
PavementPounder's Avatar
The rear axle doesn't care what carrier the front has as long as the gears match.
Are you not allowed to buy the Detroit anywhere else or something? Its not like a 35-spline 4.56-up Detroit doesn't exist.
Old February 11th, 2008, 06:47 PM   #7
kkodet
kkodet's Avatar
Thick gears with a 4.10 down carrier is the only way I know of that you can get 5.13s these days for a high pinion. I believe thin 5.13s were discontinued, but some parts houses might still have some.
Most rear 60 carriers have 30 spline side gears, which will not work with the front 35 spline shafts. You will have to use a different carrier, or swap out the carrier side gears.
Old February 11th, 2008, 06:58 PM   #8
Jeepaholic
Jeepaholic's Avatar
Just buy a 4:10 down detroit and thick gears
Old February 11th, 2008, 07:43 PM   #9
PavementPounder
It was the locker he said he couldn't find, but he was only looking on one site.
Page generated in 0.29836 seconds with 50 queries
