snowmobile idler wheel removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 9th, 2008, 07:05 PM   #1
dirtrider
Dopey
dirtrider's Avatar
Default snowmobile idler wheel removal
any got any tricks to getting off both idler wheels, the shaft just wants to keep spinning on me, normally i break one loose then tighten it up really good again and loosen the other side but no luck this time. any help?
dirtrider is offline   Reply With Quote
Old February 9th, 2008, 07:11 PM   #2
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
vice grips on shaft
Old February 9th, 2008, 07:25 PM   #3
dirtrider
Dopey
dirtrider's Avatar
i hate to do that and put teeth marks where the bearing rides
Old February 9th, 2008, 07:29 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I have had issues where the shaft spun in a housing and couldn't be held. I drilled a 1/4" hole in the whole thing and dropped a bolt in it and then it was held so it could be serviced. then when done you can screw a grease zerk in the hole of the sleeve and plug the hole.
Yetti
Old February 10th, 2008, 08:14 AM   #5
getsome
Lookin 4 Accessories
getsome's Avatar
try to get one side bolt removed, then replace with really shorter 1/2 long or so w/ lckwasher and retighten, then get the opposite side loose. easier to get short bolt out last. good luck don't go to short and pull the threads out eh !
getsome is offline   Reply With Quote
Old February 10th, 2008, 03:03 PM   #6
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
I have been lucky and the impact has always removed them. If you can get one side out you can use visegrips to hold it and remove the other side. Then just smooth the shaft and reinstall.
Old March 24th, 2008, 08:44 PM   #7
grega1967
Use an impact
grega1967 is offline   Reply With Quote
Old March 25th, 2008, 07:27 AM   #8
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
good luck...I know these can be a PITA.
piece of advice, once you do get it apart, coat all bolts with anti-seize to make future disassembly a breeze
gotsand? is offline   Reply With Quote
Page generated in 1.95344 seconds with 47 queries
