Question on towing a pop-up - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2006, 09:43 PM   #1
Tinsu
Tinsu's Avatar
Default Question on towing a pop-up
So, I am looking to purchase my first Pop-Up Camper. Probably a small used unit like Palomino Pony or Starlight 1701 - GVWR is under 1,500 for these trailers. I will tow with the 2004 GC 4x4 Laredo with 4.0L I-6 engine. No factory tow package. Class III hitch. Manual says towing capacity is 3,500.
I have talked to a local dealer who said I'd have no problems hauling such a PUP. Just hook it up and go. No trans cooler needed or brakes for the trailer.
I am wondering what you think?
Do you suggest a trans cooler?
Brakes on the pop-up?
Any suggestions or warnings?
Thanks in advance.
Tinsu is offline   Reply With Quote
Old March 23rd, 2006, 09:48 PM   #2
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
trans cooler is always good, I do not think you would need it. I towed a Palamino with my 5 speed 2.5L YJ with no trouble. I towed a heavier pop up with my 2.8L S-10 with even less trouble (less drag from the aerodynamics of the tow vehicle) Our 3.8L buick station wagon pulled the heavier pop up easily, never knew it was back there. That was a 21' starcraft with full fridge, sink, porta potty and furnace, fiberglass beds and heavy canvas for winter camping.
Old March 23rd, 2006, 09:57 PM   #3
Shakr
formerly square eyed rio
Shakr's Avatar
I have pulled my pop up with my GC with no prob what so ever , I do have the tow package .My pop up is a 12 ft and opens to a 24 ft.
I have pulled this with a aerostar, astro and venture also with no probs.
I will say make sure you sit level and not tongue up or down the trailer will sway if not level. My venture has adjustable air shocks and I have a drop hitch upside down to keep it level and it pulls like a dream . I would like to add MAKE SURE YOU DO NOT PULL IN OVERDRIVE , my aerostar pulled fine in od but it cost me a trans.
Good luck and have fun . Camping is great and really great when you dont sleep on the ground .
Shakr is offline   Reply With Quote
Old March 23rd, 2006, 10:06 PM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I always put a cooler on...why not? They are cheap, easy to install and you don't need to worry anymore.
Old March 23rd, 2006, 10:23 PM   #5
JEEPR
Playing Possum
JEEPR's Avatar
You will be fine. A trans cooler is always a good idea, even if you don't tow.
JEEPR is offline   Reply With Quote
Old March 23rd, 2006, 10:25 PM   #6
Blonde with a doggy
The southern gal
Blonde with a doggy's Avatar
Should be fine, I towed a pop-up with a 00 XJ I6 no problem.
Blonde with a doggy is offline   Reply With Quote
Old March 24th, 2006, 06:39 AM   #7
84Scrambler
It's a Chrysler transmission. Put a cooler on it...
Cooler < $100
Tranny > $2,000
Simple math.
Old March 24th, 2006, 07:13 AM   #8
Tinsu
Tinsu's Avatar
Good advice. Thanks.
Old March 24th, 2006, 08:08 AM   #9
badazzamc
Get Some
badazzamc's Avatar
it will tow fine but i would always install a trans cooler.
Old March 24th, 2006, 07:47 PM   #10
Tinsu
Tinsu's Avatar
I will definitely install the trans. cooler. Great advice from everyone.
About the brakes, I looked at the spec sheets on a couple of models that I am interested in. All say "electric brakes are optional." So, can I assume that the unit is prepared to receive them and I can have my local RV dealer install them?
Old March 24th, 2006, 07:56 PM   #11
junk90xj
ALLPRO AUTO
junk90xj's Avatar
yes the dealer will install them for you, but you dont need them with a gc.
throw a cooler on and go campin
http://www.apalansing.com/
Old March 25th, 2006, 07:49 AM   #12
Tab
Tab's Avatar
You have to trade your truck in for an H3. I hear they're tow monsters. Its the only answer.
Old March 25th, 2006, 07:54 AM   #13
JEEPR
Playing Possum
JEEPR's Avatar
You shouldn't need trailer brakes for a trailer that small. Unless you are buying new and the dealer wants to give you a screaming deal on a set. You can always add them later if you feel you need them.
Old March 25th, 2006, 08:10 AM   #14
sledder
2257 Compliant
sledder's Avatar
In the overall scheme of things it is not a real big trailer. Should be able to hook on to it and go. Trans cooler would be OK if you want one. I personally would give consideration to the brakes. Your rig is certainly big enough to stop it but trailer brakes would help keep everything in line if you really have to stop. One option you won’t regret in case you really have to haul it down. Important to us ADD types.
Good Luck
Mike
sledder is offline   Reply With Quote
Page generated in 0.32540 seconds with 64 queries
