reuse ring gear bolts on 14b? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2008, 08:27 AM   #1
Tab
Tab's Avatar
Default reuse ring gear bolts on 14b?
I've set up about a dozen ring and pinions but the install kits have always came with new ring gear bolts. The 14b kit does not and I know you are not supposed to but from those that have actually set up gears do you think it will really matter? Oh and its a 1999 axle with 60,000 miles on it if that matters, it hasnt been sitting in the weeds for 20 years or anything.
Old February 8th, 2008, 09:57 AM   #2
Bones
Bones's Avatar
I have always reused them. That doesn't make it right I guess, but thats my .02
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 8th, 2008, 01:57 PM   #3
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I had to reuse mine in my 30. Since the POS ones I got in my install kit pulled the threads off of them.
Old February 8th, 2008, 02:20 PM   #4
Tab
Tab's Avatar
I always thought that the bolt stretches slightly when put into its optimum torque range thus giving it its strength. So with that, does a bolt lose its elatisity if never over tightened? I understand the thought of a lock nut and that they should not be reused, or at least understand that they lose their efectiveness after use, but a bolt should be fine. Maybe someone who is smarter than me (not too hard) could explain if I'm wrong. Till then If I get that far this weekend I'll re-use them. Thanks
Old February 8th, 2008, 02:39 PM   #5
Pokerob
hug life
Pokerob's Avatar
x2
Old February 8th, 2008, 02:40 PM   #6
kevinr839
kevinr839's Avatar
same here
kevinr839 is offline   Reply With Quote
Old February 8th, 2008, 03:33 PM   #7
Some fasteners are torque-to-yield, some aren't..
I've always reused ring gear bolts without issue.
Look at all the lock rite installs when you need to remove the ring gear. They don't include new ones.
Old February 8th, 2008, 04:10 PM   #8
Tab
Tab's Avatar
good point Jesus . I figure the oem is better than aftermarket anyways. Thats it! Their going in in the morning. Thanks
Old February 8th, 2008, 06:11 PM   #9
chris1044
chris1044's Avatar
Some fasteners are torque-to-yield, some aren't...
While I wouldn't hesitate to re-use ring gear bolts, provided they look OK, this is an interesting topic.
As you stated, some fasteners are torque-to-yield and some aren't. The ones that are not, surely you're not exceeding the bolts elastic deformation point (aka point at which it yields). Does anyone know if the torque-to-yield fasteners reach the very point which plastic deformation begins to occur at their torque spec??
The reason I ask is because pretty much everything has a saftey factor built into it, and most stuff is designed to work with loads that are below this point.....if it's the case, then the bolts haven't gone through plastic deformation and are theoretically sound.....and, theoretically sound they should have the same shear strength as when they were new (given they haven't undergone a lot of shock loading and other various abuse)
Old February 8th, 2008, 07:17 PM   #10
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I have always reused 14 bolt ring gear bolts.
Old February 8th, 2008, 07:39 PM   #11
Dunno, I switched from Mechanical engineering to electrical many years ago...
Old February 8th, 2008, 07:57 PM   #12
Bones
Bones's Avatar
even torque to yeild bolts can be re-used a limited amount of times. Example is Head Bolts. Ford design spec for current motors are 4 re-uses (5yeilds total) for gas engines, and 2 re-uses (3 total) for diesel engines.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 8th, 2008, 07:59 PM   #13
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
When do you need to remove a ring gear to install a lock rite? or should I ask what axle would require it.
Old February 8th, 2008, 09:25 PM   #14
Tab
Tab's Avatar
Some do. I know one of mine did and the other I just sanded down a ring gear tooth to slide the cross pin by. Why did Haggars name change to Jesus in my other response? Is CC bored or something?
Old February 8th, 2008, 09:31 PM   #15
groundhog
groundhog's Avatar
Use them!!!!! I did!!!!!
groundhog is offline   Reply With Quote
Old February 8th, 2008, 09:38 PM   #16
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i need a set if any one has some haha
Old February 8th, 2008, 11:26 PM   #17
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
14b ring gear bolts? What do they look like? I have a whole box of parts from Killer B that I am sure have some in it somewhere.
JcrOffroad
Zoom Zoom!
Old February 9th, 2008, 07:14 AM   #18
KILLER"B"468
Yankabilly
They are IIRC 9/16" bolts that are just under 2" long.
Casey I will check a box of ring gear bolts I have here as well.
Old February 11th, 2008, 05:48 PM   #19
KILLER"B"468
Yankabilly
I do have a set for the 4.11 and down gear sets. They are a tad over 1.750" and will need a lock washer I do not have those.
Page generated in 0.45739 seconds with 80 queries
