Going to an electric fan. Thermal switch Q - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2006, 08:12 PM   #1
wester
wester's Avatar
Default Going to an electric fan. Thermal switch Q
I'm going to be putting in a 16" "S" blade fan. My problem is that I'm not sure where to put the thermal switch. Could I just take my factory temp sensor out and run a nipple out of that hole with a "T" on it to put them both in, or would that create an air pocket so they wouldn't read right?
Also what temp switch would you recommend, I think the kit I got has a 150Deg. switch.
wester is offline   Reply With Quote
Old March 23rd, 2006, 08:24 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if your running a cooling fan you want the fan to come after the T stat opens, if your T stat is opening at 195* a 150* switch will just waste energy and ruin the fan by running way to long. if your putting in a switch make it about 20 degrees higher then the T stat so its letting the radiator do its job. the second thing is either put the switch down into the coolant or find a spot somewhere else. the heads run about 15-30 degrees warmer so the switchs there are like 230* to be most effective.
Yetti
Old March 23rd, 2006, 10:08 PM   #3
amc78cj7
amc78cj7's Avatar
http://www.jegs.com/webapp/wcs/store...tegoryId=13393
Flex-a-lite Black magic fan. Highest CFM on the market and has it's own shroud.
Comes with a thermostat and probe that goes into the radiator fins near the inlet. Its an adjustable switch so you can have the fan turn on just as the engine T-stat opens, or you can adjust it higher or lower based on the time of year.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old March 24th, 2006, 07:34 AM   #4
wester
wester's Avatar
Thanks for the link, but I already have a fan and relay kit. I just wanted a little input on themal switch placement.
Old March 24th, 2006, 02:26 PM   #5
amc78cj7
amc78cj7's Avatar
Well the probe for the thermostat switch on the black magic fan goes into the fins of the radiator just next to the inlet hose. That way when the engine T-stat opens and hot fluid poors into the radiator the fan turns on. Of coarse that was already stated in my first reply. Maybe I'm not understanding the question?
Old March 24th, 2006, 03:10 PM   #6
wester
wester's Avatar
I have a threaded type thermal switch, but I don't see where I can put it, other than the hole where the original temp sensor is. That Black Magic one would be nice but I didn't see anywhere at Jeggs where it was sold separately.
"Edit"
I think I found it. Thanks.
Page generated in 0.20965 seconds with 41 queries
