D60 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2008, 04:15 PM   #1
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Default D60 question
Looking to find out what a standard spline count would be on a 78-79 rear D60. Does 30 sound right?
Also did Ford ever use the D50 in a rear application?
C.K. is offline   Reply With Quote
Old February 7th, 2008, 04:21 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Correct 30
Not that I have ever heard of.
Old February 7th, 2008, 04:23 PM   #3
C.K.
Dont Feed the Cyco
C.K.'s Avatar
thanks
Old February 7th, 2008, 10:20 PM   #4
PavementPounder
PavementPounder's Avatar
Originally Posted by C.K. View Post
thanks
I have a 35-spline D60 carrier for sale.
Old February 7th, 2008, 10:23 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I believe that the only stock standard D60's with 35 splines are the semi float ones. Which is why a stock full float 60 is only marginally stronger than a 44 in shaft strength.
Now that I said that someone is going to pop in with information that proves me wrong.
JcrOffroad
Zoom Zoom!
Old February 8th, 2008, 08:24 AM   #6
Jeepaholic
Jeepaholic's Avatar
Late 90's E-series vans had 35 spline full float 60's with disc brakes even (and no they were not that metric pattern)
Old February 8th, 2008, 08:58 AM   #7
Blackjackbender
ill agree. there not supporting the vehicles wieght which makes them the only things that will make a bit stronger. I think thats all. correct me if I am wrong.
Nick for the price of it you may be better off building a 14bolt.
Old February 8th, 2008, 09:34 AM   #8
Jeepaholic
Jeepaholic's Avatar
That is why I had built my 70u, 35 spline with the clearance of a 60, 3.5" 1/2" wall tube.
Old February 8th, 2008, 09:57 AM   #9
Bones
Bones's Avatar
or run a 14 bolt / sterling!
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 8th, 2008, 10:18 AM   #10
PavementPounder
Or Roger's 35-spline D70 (formerly mine) that is still at my house which has all new bearings and a disc conversion with zero miles.
Old February 8th, 2008, 01:33 PM   #11
Blackjackbender
x2. 14 bolts can be made to not hang that low if your willing to shave it it and replate the bottom. Or if you want to get crazy turn the ring gear down a bit and go shave it even farther.
Old February 8th, 2008, 08:01 PM   #12
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
But isn't the 60 a much larger diameter shaft than a D44?
Nick, a D50 is only a front axle.
Old February 8th, 2008, 08:14 PM   #13
Jeepaholic
Jeepaholic's Avatar
Nope, same size 1.31"
Old February 8th, 2008, 11:27 PM   #14
C.K.
Dont Feed the Cyco
C.K.'s Avatar
What is a 70u?
PP call me this weekend if you are around.
Old February 9th, 2008, 06:32 AM   #15
PavementPounder
The 70u housing does not drop down as far as a standard D70, but you can still shave a standard D70 the same as the other axles mentioned and the bottom is smoother to start with. I can show you a pic if the shaved D70 for my XJ.
Old February 9th, 2008, 08:08 AM   #16
Jeepaholic
Jeepaholic's Avatar
Notice there is no lip on the bottom of the diff, and how smooth it is.
Old February 9th, 2008, 11:22 AM   #17
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
well no wonder so many people upgrade to 35spline shafts/carrier.:tonka:
I had a D60 ff rear in my old 79F250. It was welded and behind a 400hp motor. It took some serious abuse, and never broke.
Old February 9th, 2008, 12:19 PM   #18
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
What driving up and down the driveway? Or on and off the trailer?
Old February 9th, 2008, 12:44 PM   #19
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
This was a while back..probably before you could drive
Page generated in 0.43956 seconds with 80 queries
