Snorkeling a 1987 extended cab - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2008, 12:33 PM   #1
mybluetoy
4-wheel 4-life
mybluetoy's Avatar
Default Snorkeling a 1987 extended cab
My truck is in need of a snorkel. I try to compete in mud bogs with the big boys. I do ok but I think I can win on the right day. My last run I was running great and then got wet. It shut me right down. I need a snorkel. Homemade is the way I heard. Any and all help wanted. Thank you. You can check out my runs at unemployedfilms.com
mybluetoy is offline   Reply With Quote
Old February 7th, 2008, 12:40 PM   #2
define 'it shut me right down'
that sounds more like a wet coil/ignotor
If you want to run mud, learn how to waterproof everything under the hood.
A snorkel is simple, just get some PVC and go at it. The factory airbox already is pretty sealed, it just draws from the front. Seal that, run a pipe out the side of the airbox, then up through the fender and up the a pillar. Not rocket science..
Old February 7th, 2008, 06:52 PM   #3
Rattler
Home Sweet Homicide
Rattler's Avatar
I saw a webiste that gave a pretty good description on how to make one but I can't find it.
Old February 8th, 2008, 08:22 AM   #4
roll-bar Bob
roll-bar Bob's Avatar
rought it in to the cab
when I built mine I came out the front of the air box with 2" pvc and then used a tight 90 up-wards to clear the top of the box, there I ran another 90 straight back throught my fire wall in to the cab, it took some work to move some shit around to get a streight shot but it can be done.
ps this will make your truck loud as fukc when driving
Old February 12th, 2008, 03:50 PM   #5
sr522re
Zip tied Tough
sr522re's Avatar
I think I've seen you at those mud runs before. Have you asked the guy with the awesome tan truck that does really well with his snorkle???
sr522re is offline   Reply With Quote
Old February 12th, 2008, 03:52 PM   #6
sr522re
Zip tied Tough
sr522re's Avatar
Oh, btw, I went to www.unemployedfilms.com and thought it was pretty cool. Nice work!
Old February 20th, 2008, 12:31 PM   #7
BOGDOG
BOGDOG's Avatar
My biggest problem has been the computer location. But mine is a lowrider.
Old May 19th, 2008, 12:29 AM   #8
ToyinAround
Trust Me....
ToyinAround's Avatar
I lost a motor once because of Toyota's poor choice of air intake myself. I got rid of that piece behind the headlight and just cut a hole in the inner fenderwell so i could run 3in PVC from the tube off the front corner of the airbox into the space behind the fender and ran it back near my door hinge. Now when i charge into water-mud holes i don't get water in my airbox anymore.
ToyinAround is offline   Reply With Quote
Page generated in 0.28425 seconds with 48 queries
