tj 44 rear disc conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2008, 08:18 PM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default tj 44 rear disc conversion
i am swapping in a new front axle and the bolt pattern will be 5x5.5 which means i have to change up the rear bp so i need a way to convert the rear to discs and go to 5x5.5 i am getting the new rear shafts with dual bp's and im thinking ill have to find some rear rotors that are roughly the same size as stock tj fronts but with 5x5.5. any ideas?
nate4d is offline   Reply With Quote
Old February 6th, 2008, 08:21 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Use the Zj or newer Tj disc and redrill it to 5x5.5
Old February 6th, 2008, 08:31 PM   #3
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
or you could just upgrade the rear to TJ disc brakes and pickup some spacers for the rear with the different bolt pattern. which helps run the wider tires also.
I believe I might have an extra set of calipers and rotors for the rear
TJrockdogg is offline   Reply With Quote
Old February 6th, 2008, 08:44 PM   #4
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Go to the dealer and order the backing plates form a 03-06 Rubicon or call the local junk yards they might be able to get you them.
Then go to NAPA and order the rotors, calipers, pads, ect. Just redrill the rotors to 5 on 5.5 no point on spending the money on spacers if you need to buy new rims and you're buying dual pattern shafts.
Old February 7th, 2008, 12:08 AM   #5
Blackjackbender
do what I have been telling you for months.
ZJ rear disc conversion. i have sent you like 10 write ups on it.
Old February 7th, 2008, 06:07 PM   #6
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Do what BJB said. He's my hero.
C.K. is offline   Reply With Quote
Old February 7th, 2008, 06:15 PM   #7
Blackjackbender
x2
Old February 7th, 2008, 06:35 PM   #8
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Old February 7th, 2008, 07:39 PM   #9
nate4d
Gnarley Davidson
nate4d's Avatar
im thinkin the new backig plates will be best. anyone got a list of exactly what i need or maybe napa part numbers?
Old February 7th, 2008, 08:19 PM   #10
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Do you want us to come over and put the damn thing on to? Use the link Tyler sent you in PM's or go to NAPA online and look you koon.
Old February 8th, 2008, 08:25 AM   #11
Blackjackbender
www.stu-offroad.com there is a write up on there. i think there actually is a couple.
Old February 8th, 2008, 08:26 AM   #12
nate4d
Gnarley Davidson
nate4d's Avatar
thanx
Old February 8th, 2008, 08:29 AM   #13
Blackjackbender
http://stu-offroad.com/suspension/d44brake/bc-1.htm
Old February 8th, 2008, 08:38 AM   #14
nate4d
Gnarley Davidson
nate4d's Avatar
checked em out. looks like i got what i need.
Page generated in 0.40330 seconds with 65 queries
