Anyone use CPVC to plumb a house? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2008, 08:33 AM   #21
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Originally Posted by Rob the plumber View Post
Agreed. It is the new trailer pipe.
It is easy, and it does satisfy code requirements. I would only use it if I were forced to though. :)
Did you just say Pex is Trailer Trash.
FORD FLARESIDE is online now   Reply With Quote
Old February 7th, 2008, 09:11 AM   #22
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
x2 on the bread trick. copper is pretty easy nowadays with the presoldered connectors. flux, heat until it squirts out. however it can be a pain in the arse if it's like my house and the pipes are tight to the floor joists. I really need new shut offs in my lines so I just keep repairing them
Old February 7th, 2008, 10:24 AM   #23
yj93
yj93's Avatar
A friend of mine just bought a new house here in Ypsi Twsp. He said the builder told him that CPVC is a requirement by the township now. It's pretty cool, looks like a gigantic spider in his basement... Loks similar to this-->
I had the hard PVC in my old house, only problem I had was at the hot water heater, where the PVC met the copper. It leaked (dripping) 2-3 times, the builder finally replaced the joint.
yj93 is offline   Reply With Quote
Old February 7th, 2008, 12:42 PM   #24
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Originally Posted by chris1044 View Post
Jamb a piece of bread up the copper pipe so the water won't make its way to your joint while you're soldering.....after you're done the bread will dissolve and you'll be good to go
I'll smash my hand with a claw hammer if one more homeowner tells me about this neat trick.
Old February 7th, 2008, 12:44 PM   #25
Rob the plumber
That sir, is Pex. So easy Mexicans by the carloads will be plumbing houses in minutes. :)
Old February 7th, 2008, 12:45 PM   #26
Rob the plumber
CPVC is.
Old February 7th, 2008, 12:52 PM   #27
xjmichigan
xjmichigan's Avatar
Rob, did you ever hear about jambing a piece of bread up the copper pipe so the water won't make its way to your joint while you're soldering.....after you're done the bread will dissolve and you'll be good to go!
Old February 7th, 2008, 07:07 PM   #28
9T9BlueTJ
Motivator, please!
9T9BlueTJ's Avatar
If you go copper, you need to be aware of the electrolysis that will eventually eat out the lines due to the weak electrical current water causes while running thru the lines. My parents had to replace a line that eroded that way (lasted 30 years), and another buddy had to replace a line within 10 years. He ended up running it to a ground and solved the problem.
CPVC and PVC will last quite a while if it is not exposed to sunlight or high temps (i.e connected directly to a water heater).
9T9BlueTJ is offline   Reply With Quote
Old February 7th, 2008, 07:12 PM   #29
IPLUMB
IPLUMB's Avatar
Talking
That Sir is some funny shit
IPLUMB is offline   Reply With Quote
Old February 7th, 2008, 08:21 PM   #30
Rob the plumber
"I still got one good arm to hold you with Ellie May"
Old February 7th, 2008, 08:44 PM   #31
PavementPounder
PavementPounder's Avatar
I have PVC and don't like it much. The faucet shot off the wall at me once while taking a shower. I used purple Crazy Glue on it and it never came off again.
Old February 7th, 2008, 11:44 PM   #32
IPLUMB
IPLUMB's Avatar
PVC? or CPVC? Two completely different things. PVC Not allowed for water distribution, CPVC is approved.
Old February 7th, 2008, 11:45 PM   #33
PavementPounder
Whatever. The non-flexible plastic shit.
Old February 7th, 2008, 11:57 PM   #34
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
My dad and I just built a house two years ago and we used all copper. Even the supply line from the road is copper. And FYI a ground strap on your cold water line is code.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Page generated in 0.45745 seconds with 64 queries
