snow blower problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2008, 06:52 PM   #1
unclemyke
Default snow blower problems
got an old ariens 2.7 2-stage. this thing won't run wot. starts to sputter and pop. then it dies. i can keep it going(kinda) by pushing the primer bulb a few times, but eventually it dies. hope one of you small engine guys can help.
unclemyke is offline   Reply With Quote
Old February 6th, 2008, 06:55 PM   #2
Gunsworth
Gunsworth's Avatar
clogged fuel filter?
Old February 6th, 2008, 06:56 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if it has a float bowl beneath the carb take that off and see what if any junk is there and clean it out as well as spray some carb cleaner in the bottom of the carb specifically the jets.
Old February 6th, 2008, 07:03 PM   #4
unclemyke
no filter...no bowl. it's just a diaphram type carb.
Old February 6th, 2008, 07:06 PM   #5
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
the diaphram in the carb could be bad, have a small tear or something?
71jeepster is offline   Reply With Quote
Old February 6th, 2008, 07:08 PM   #6
unclemyke
carb was just rebuilt by this small engine repair guy down the road. when i first got it back, it was fine. all of a sudden it's runnin' like crap.
Old February 6th, 2008, 07:11 PM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
switch to shovel. All fixed
Old February 6th, 2008, 07:12 PM   #8
caveman
GeoDude
caveman's Avatar
take it back maybe
Old February 6th, 2008, 07:20 PM   #9
88mudder
In the band!
sounds like its starving for fuel. If the carb was redone it should be good...
Old February 6th, 2008, 07:39 PM   #10
71jeepster
71jeepster's Avatar
there isn't anything else it could be, those engines are pretty simple, is there a crack in the gas hose or primer ball that air could be getting into? Sounds like there is definitely a fuel issue, I'd take it back to the guy and ask him what's up with it.
Old February 6th, 2008, 08:16 PM   #11
SinisterX
I Drank WHAT!
SinisterX's Avatar
Send a message via MSN to SinisterX
Yea that x2 and also dump the fuel and put known good in it.
SinisterX is offline   Reply With Quote
Old February 6th, 2008, 08:49 PM   #12
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Did ya shut off the choke?
Old February 6th, 2008, 10:39 PM   #13
deuce228
Redneck Poser
deuce228's Avatar
Is there a shut off valve that is not fully open?
laugh all you want but I had a buddy damn near dismantle his machine to find out he forgot to open the shut off
Old February 6th, 2008, 10:48 PM   #14
unclemyke
gas is good. no shutoff. pulled the carb apart. blew it out. kinda bent the metal diaphram peice upwards so it would open the needle more. now it seems to run great again for a few minutes. then i put a load on it(wet snow) and it wants to die. i hate to have to take it to a shop for $32 minimum and an unknown maximum.
Old February 6th, 2008, 10:54 PM   #15
71jeepster
71jeepster's Avatar
sounds like you found the problem as something with the carb again!
Old February 6th, 2008, 10:58 PM   #16
88mudder
In the band!
hmmm...this might sound stupid but how old is the gas?
Old February 6th, 2008, 11:08 PM   #17
71jeepster
71jeepster's Avatar
that was already mentioned!
Old February 6th, 2008, 11:09 PM   #18
88mudder
In the band!
good eye, partner
Old February 6th, 2008, 11:11 PM   #19
71jeepster
71jeepster's Avatar
good eye, partner
a little better then yours
Old February 6th, 2008, 11:17 PM   #20
88mudder
In the band!
hey man..ive never worn glasses, contacts, or anything in my bigass 18 years of life!
Im out , goodluck with the engine!
Page generated in 0.44612 seconds with 82 queries
