Ring seal - leaks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2006, 03:41 PM   #1
Just a Spouse
Motrcytman's spouse
Just a Spouse's Avatar
Default Ring seal - leaks
Can a 'ring' leak cause oil to leak so that it is low in the oil pan, but not leaking on the ground so you can't easily see that it is leaking? This is on a chevy engine.
Thanks!
Sorry, I'm not very mechanical.
Just a Spouse is offline   Reply With Quote
Old March 23rd, 2006, 03:45 PM   #2
What specifically makes you think its a issue with the rings? (I assume you mean piston rings).
If you have bad rings, a compression test probably would show this, and I'd expect blowby/pressure in the crankcase.
If you have bad valve seals that are leaking into the chamber, it could cause some oil consumption issues.
Are you seeing blue smoke from the exhaust?
Old March 23rd, 2006, 04:12 PM   #3
Just a Spouse
Motrcytman's spouse
No blue smoke, one of our daughters took it to a dealership that said it is leaking around the seals, but I'm not sure if I can trust what they tell a cute blonde who is clueless about cars and engines....
Old March 23rd, 2006, 04:54 PM   #4
Well, if oil is going away, its gotta be going somewhere.
If its leaking externally, enough to drop the levels between oi changes, well, its obvious, since theres going to be oil all over the engine somewhere.
If not, then its getting consumed/burned. There really isn't anywhere else for it to go.
I'd try pulling the plugs and looking at them. Bad valve seals usually make for oily looking plugs.
Also look inside the air intake, see if its really oily/sludgy.
Old March 23rd, 2006, 06:10 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
before you condem the engine and rings try changing the oil and using some good quality oil. I have seen cheap crappy oil burn past rings in good engines with nothing wrong, sometimes just changing out the cheap stuff will save the day
Yetti
Page generated in 0.23862 seconds with 38 queries
