So Important I Asked Twice-Hi Steer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2008, 02:28 PM   #1
aimmotorsports
aimmotorsports's Avatar
Question So Important I Asked Twice-Hi Steer
whats the most comon used tie rods? i need to replace mine soon and am trying to figure out what was used. i can post pics of mine if needed later tonight when i can get out to my truck.
aimmotorsports is offline   Reply With Quote
Old February 4th, 2008, 02:41 PM   #2
Most hi steer setups use 1.25 x 0.25" wall DOM, with FJ80 tie rod ends.
No idea what the length is, since my front is no longer stock width... but I run that size tube.
Old February 4th, 2008, 08:49 PM   #3
aimmotorsports
heres the pics...
ID:	20433   Click image for larger version
Old February 4th, 2008, 08:51 PM   #4
aimmotorsports
my tie rods need to be replaced and i dont know what there are from. i think they are not stock. truck is a nissan hardbody with toyota solid axle with high steer. need to know asap. truck needs to be on the road this weekend.
ID:	20435   Click image for larger version
Old February 4th, 2008, 08:59 PM   #5
Bones
Bones's Avatar
you mean the booty-fab steering? Maybe a chevy tie rod end? The heim joint is just a universal size
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 4th, 2008, 09:22 PM   #6
aimmotorsports
yeah, just the tie rods...
Old February 4th, 2008, 09:30 PM   #7
Well, lets see...
Look like maybe FJ60 rod ends, with that funny end with the hole in it.
christ, thats crazy looking. Is that a flipped toy axle, with the diff on the drivers side? Unless you cut and rotated the knuckes......blech..
What kind of steering arms are they? Is there just one hole on both? Or is there two holes in one arm?
I'd huck it all in the garbage and call Marlin....
Old February 4th, 2008, 09:44 PM   #8
Here's a few pics of what it *should* look like...
Marlin hig h steer arm, passenger side should have two holes for the tie rod and drag link...
Drivers arm should have one hole for tie rod only.
Hmm, looking more at the FJ60 and 80 ends (see them on this page: http://www.pirate4x4.com/forum/showt...&page=12&pp=25 ) I think Bone sis right, those look domestic, which means whatever arms you have are tapered for domestic.
I'd throw it all out and start over, myself.
But, barring that, you could start by getting some chevy tie rod ends from autozone and see if they match the shank size.
Old February 4th, 2008, 09:45 PM   #9
aimmotorsports
yeah it looks fliped. i think its only one hole in each arm. truck has been built and wheeled for several years with this set-up. i believe the knuckles were cut and rotated. still trying to figure out everything that was done to this truck.
Old February 4th, 2008, 09:46 PM   #10
And trim your U-bolts, for gods sake, man...
Another thing.... are you running the torque arm off the left side? Thats only there for if you are running push-pull steering, not crossover. Ditch that.
Old February 4th, 2008, 09:52 PM   #11
aimmotorsports
i bought the truck how it sits. i will be triming the ubolts and adding shocks this week. waiting on the tabs i have on order to come in for the shocks. i will get more pics of the set up in the morning. im not sure exactly what was done. any help would be great. this is my first 4x4 other then stock trucks. anything you would like to see in picticular?
Old February 5th, 2008, 11:58 AM   #12
smasheromalley
smasheromalley's Avatar
By the looks of the torn dust seals, and how it appears the tie rod end stud is kind of cocked in the knuckle... It looks like you need to throw it out and start over. If the tie rod stud doesnt fit the hole in the knuckle thats bad mmmk
Old February 5th, 2008, 02:08 PM   #13
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Replacing the tie rod end is not going to fix the driver side, two that looks like a tractor heim on the drag link?
Easier to start off new
Old February 5th, 2008, 02:14 PM   #14
yeah, big ugly coarse threads...
Old February 5th, 2008, 02:18 PM   #15
Probably the easiest thing is:
1) find the correct left and right side tie rods. Again, probably easiest to grab some chevies from the store and check them to see if they fit. If not, take thme back. But they should be in stock somewhere locally.
2) Make a new, strong tie rod.
3) Somewhere that it will fit, weld two tabs to the tie rod that stick up, with a mounting hole through them. Use that point to attach the drag llink through a new heim joint.
.........._____
......../....o...|
Kinda like this, looking from the front...
Old February 5th, 2008, 05:57 PM   #16
aimmotorsports
any year chevys or? was told they are toyota's for the previous owner. tried lookin at a few pics, but, they dont look toyota to me. theres 2 heim joints on that shaft. i was going to replace them both. was thinking about makeing the new rods for it. its bent a bit on the left side.
Old February 5th, 2008, 06:04 PM   #17
aimmotorsports
just saw this while looking for tube ends. the tie rods kind look like these...
http://www.ballisticfabrication.com/...p_16-1203.html
Old February 5th, 2008, 08:26 PM   #18
jeepguy74
jeepguy74's Avatar
take the tierod off and take it with you to the parts store... they will have a book or computer that will have pics to match it up with......i know that auto value and nappa have the book and autozone and advanced auto have the computer to look it up......
that would be the best way i can think of to do it...but i agree that you need to make a new design all the way across when you get new ends...
Old February 6th, 2008, 02:39 PM   #19
Where did all of the other posts go?
Old February 6th, 2008, 02:59 PM   #20
aimmotorsports
its in the general section also...
Page generated in 0.34333 seconds with 84 queries
