Project Sidewinder - YJ frame up - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2008, 07:55 PM   #1
Crash8212
Crash8212's Avatar
Send a message via AIM to Crash8212
Default Project Sidewinder - YJ frame up
This first post is LONG due to me procrastinating on starting the build thread. Now I am playing catch up.
My dad and I caught the jeep-bug last summer. He bought a 92' YJ with 2" lift and 31's. It has a 2.5L was intended to be a toy up at he cabin (near Harrison, MI). We took it out and wheeled it a little but it just didn't have the 'oomph' to climb the hills or get through the bogs. We both looked at a specific hill while up one weekend and in true Arnold fashion "I'll be back!"
So the project started in mid December with a 90' YJ rolling chassis (frame, axles, "clean tub"...more on that following, and a 2.5l motor) The chassis was purchased on Ebay from a seller in New York, New York. It was claimed as 'rust-free' and the pictures reinforced that claim. My dad and his friend took the 10 hour trek to buy the chassis only to find that it was CLEARLY not a rust-free chassis. He bought it anyway ($600) and brought it home. The intention was to have to spend as little time doing bodywork as possible, this was not going to be case now.
After getting a plan of action, we found a 92' 4wd Blazer with a 4.3 auto (no bitching about a v8! I've heard enough) and bought that for a donor. First step was to strip the Blazer of all necessary parts and get it out of the way. The motor/tranny/t-case we're pulled all in one piece. Everyone said it couldn't be done without lifting the body off the mounts... I beg to differ (wasn't easy I'll admit). The entire engine and computer harness were removed, fuel sending unit along with computer/aldl and a few necessary electrical components from the interior. The radiator was saved and a few other little misc. items that may come in handy later (the seats for example). The blazer was then put outside as a catch-all for scrap parts.
[IMG][/IMG]
(the 4.3 pulled)
(the mess that will be the wiring)
Next came the YJ frame/tub. The tub was removed from the frame and my dad started on repairing the ridiculous rust holes. I started working on the frame modifications.
Now would be a good time to explain what the original intentions were for the project; - A trail worthy Jeep that could make it over/through ANYTHING that we would encounter in the area that surrounds the cabin and still be somewhat streetable however it would see very minimal concrete time. Now this means somewhat harsh trails and some steep hills and ruts but very little rocky terrain. The engine would be a TBI 4.3L in the 200hp/270tq range with a 700R4 tranny mostly stock. Suspension intended was an SOA lift, stock axles (mostly) and running on 35's (I know, don't scream yet....its coming).
The frame was completely stripped and wire-wheeled to prep for the coating of POR-15. The can says "use in well ventilated area"... you would think "DUH" right? Not always an option when in a heated barn and it is 9 degrees outside. Full face respirators were a life saver in that endeavor.
(check out that haze!)
(Caution: Wet Paint)
Now I tried to convince my dad that the stock rear would never hold up to 35's after doing a little reading (not comfortable with stock front either, but no rock crawling in its future...if it breaks, it'll get a 44). AFTER I ground the perches off and cleaned up the Dana 35 and got it ready, we found a Ford Explorer 8.8 with 4.10's, LS and disc at a local scrapper. I then had a hay-day with grinding on that. It has been fully set up for the SOA and is awaiting the engine/tranny mount up for the correct pinion angle. It also got all new emergency brake components/disc-drum/pads and new fluid. The gears looked great (only 58k miles I was told...). After it was all cleaned up and ready for spring perch positioning, my dad welded the tubes and the pins to ensure we don't end up spinning a tube. Probably wouldn't happen with a 4.3 but now it definitely wont.
(starting the grinding)
(new brakes and tubes welded)
Originally for the front suspension we intended on using a "Z-link" drag link and a drop pitman arm to correct the bumpsteer. After being scolded by everyone I came across and reading how dangerous the setup really is, we ordered the JB-raised steering bracket. I installed that in a short period and I am extremely happy with the results. Anyone considering doing the high-steer custom knuckle setup for the Dana 30, please please please save your time and money and order the JB-RA. Will save you sooo many headaches. The front Dana 30 is going to be left in but unsure of its future as of yet. It may get Alloy USA upgraded shafts (1-piece so no posi-lock BS) or we may keep an eye out for a HP Dana 44. Not crazy about going through the hassle of that high-steer setup at all though.
(SOA perched with massive stupid strong anti-wrap perches)
(drilling/tapping holes for JB-RA)
(bracket installed with extended drag link also)
Now you have to take into consideration that we only work on this for a few hours a day and that is pretty much restricted to the weekends only for me. I have (more or less) completed the chassis short of shocks and a few little odds-n-ends and my dad has fought with the tub for this period as well. He originally intended, as stated earlier, that bodywork was to be minimal at best because "we are just going to tear it up anyway". Well, he is a PERFECTIONIST (borderline anal) and couldn't let anything go. I don't know if anyone has ever scrutinized the stock body work on a YJ tub but right off the line it is HORRIFIC! This is now the straightest dang YJ tub in the area (and if it isn't you'd better not mention otherwise). He replaced all the problem areas in the tub and you can't even tell a single spot where steel was replaced unless you see the following pictures.
(passenger rear wheel well - BEFORE)
(cut out)
(first puzzle piece)
(Stamped - DONE)
(drivers reinforcement post replaced, yes it was ground smooth after pic)
(passenger replaced)
(under tailgate W.I.P.)
I didn't put all of the pics up showing all the spots replaced as it would take 3 yrs to load the page and I think I over did it as it is. I'll post the finished body pics up later. I haven't uploaded them yet.
Now this is where we sit as of right now. The tub is primered and ready for base/clear. First the inside will be POR-15'd then coated with Herculiner. The frame/suspension is nearly completed except for bumpstops, boomerang shackles (on the way) and add-a-leafs.
(as it sits right now on stock rollers)
The motor build will start in the coming weekend and things will really start to take shape. The transfer case from the Blazer (231C-HD) was fitted with a Tera-flex SYE on Sunday. Its not too difficult of a job but take your time, pay attention and KEEP IT CLEAN. I also had a 231J on the shelf that I tore down to compare the two. The 231C-HD really IS HD! 6 planetary gears and wider chain alone are enough to convince me. I wish I had taken pictures to display what I am explaining but to anyone that doesn't have the $ for an Atlas or Dana 300, the 231C-HD would be a better choice everytime vs. the J model.
Current tire size choice is favoring 35's but 37's have been considered deeply. Its all in whether or not we have the featherfoot to prolong the front axle life.
More later....I think I've stared at this screen long enough.
Crash8212 is offline   Reply With Quote
Old February 4th, 2008, 09:27 PM   #2
tweak
Are we there yet?
tweak's Avatar
Looking good. Keep the updates coming as you move along!
Old February 5th, 2008, 02:21 PM   #3
Crash8212
Crash8212's Avatar
More to be posted tonight. Going to finish up posting the body work and whatever progress is made in this evenings session.
Old February 5th, 2008, 03:13 PM   #4
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
FWIW My 37's actually measure 35.5 :tonka:
Body work is looking good.... wish my flatties was that clean, I would have to use less filler :tonka:
Old February 5th, 2008, 03:24 PM   #5
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
nice work. you'll like the 4.3. my dad has a carb'd 4.3/700r4 in his 87 and not only does the it get up and go, but gets really good gas mileage too.
Old February 7th, 2008, 10:49 PM   #6
Crash8212
Crash8212's Avatar
Here is a little background on the body work that has been taking place of the past few weekends.
Starting off was a tub that was supposedly 'rust-free' according to an online seller over Ebay. It was definitely not the truth.
I've already posted a few repairs of the passenger side 'cab-corner' (not sure what it would be called in a Jeep)
I'll try to show what was started with but not many pics were taken before work had started....
(bottom of tub before being touched)
(bottom coated in "Chassis Saver" after being repaired and rust-free)
(under tail gate, steel was paper thin and fingers could be pushed through)
(tailgate area rust removed)
(replacement panel welded in and welds ground off)
(ready for primer)
(told ya it was ready)
(tacking in patch pieces for pass. cab corner)
(welding in outer skin)
(LOOK! Dads making a JEE!)
(by god it better be flat now!)
(Michelangelo eat your heart out!)
It was a long and arduous process but the tub is finally ready for a base/clear coat. What I didn't show is there were about 50-60 drilled holes in the tub in various locations that someone had mounted anything and everything they could think of from speakers to screwing down carpet....it was quite rigged. So all those small weld spots you see are slugs welded into holes and ground over.
The inside will be painted with a Herculiner or equivalent (suggestions?) The final outside color is going to a standard red as will be the inner coating. This is how the tub is sitting right now. It is at a stand still until we get a decent 45+ degree day so it can be sprayed outside. One benefit to painting in cold weather (and one of the only ones) is you can paint outdoors without worry of bugs landing on your wet paint!
Oh...I'm giving KUDOS to my dad on this one. He put some time into this baby even though he is well aware of its likely future treatment.
I know I posted a ton of pics but I have TONS more so if anyone wants to see detail of anything else done, feel free to ask.
Old February 7th, 2008, 11:08 PM   #7
SBC YJ
Heavy Chevy
SBC YJ's Avatar
Nice...I'm doing the same thing to mine really soon. I don't think that my tub is so rough though. Most of my rust is under the tail lights and the corners there and below the tail gate where yours was.
Check into Durabak for the roll on bead liner. It's a little more expensive but you get what you pay for. It's UV protected and you can roll it on in the middle of winter.
I'm going to Durabak on mine inside and out...they make many color choices and comes in smooth and rigged finishes. I would hate to put a expensive paint job on mine that i know i would scratch. check out www.durabackcompany.com
SBC YJ is offline   Reply With Quote
Old February 7th, 2008, 11:13 PM   #8
Crash8212
Crash8212's Avatar
For the outside we are going to use (my dad knows more about the painting aspect) a paint called "Essentials" (I think....) It is used by companies that paint work trucks like propane-trucks, utility trucks, dump-trucks, garbage trucks, etc. Supposedly its tough as nails, we are looking into it further.
Old February 7th, 2008, 11:43 PM   #9
SBC YJ
Heavy Chevy
SBC YJ's Avatar
sounds cool...let me know what you find. I'm still open to ideas
Old February 8th, 2008, 05:31 AM   #10
You guys are doing a nice job.
Don't forget an anitwrap/ traction bar with your spring over.
Old February 8th, 2008, 05:57 PM   #11
Crash8212
Crash8212's Avatar
We are setting up for a "BAM BAR" (so its called). Just looking for a place that carries a suitable delrin bushing locally before we order online. Everything else is already on hand and ready for fab work.
Old February 26th, 2008, 08:01 AM   #12
jeepfreak81
81 inches of fun
Updates?
Page generated in 0.46302 seconds with 59 queries
