weld it or buy a spool - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2008, 07:38 PM   #1
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
Default weld it or buy a spool
i have a dana 60 from a 79 f-250 that im installing in my ranger. would i be better off welding the spiders and if i break something ill have to replace the whole carrier or should i just suck it up and spend the 150 bucks on a spool.?
muddywater is offline   Reply With Quote
Old February 4th, 2008, 07:42 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
weld it, if you do it good no breaky
Old February 4th, 2008, 07:58 PM   #3
kickstand
circling the drain
kickstand's Avatar
Spool.
I have never been a fan of welding the rear axle.
Just for the simple fact that if/when it brakes you make a mess.
If you spool it then you have to brake the carrier or spool to have problems. I am speculating but I would think that the weld would brake before the spool or carrier would.
With that said tons of people have welded rears wth no problem. I just prefer to do the spool.
Old February 4th, 2008, 08:02 PM   #4
88mudder
In the band!
spool it.
Old February 4th, 2008, 08:03 PM   #5
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
just weld the spiders together, dont weld them to the carrier, that way if it breaks, u dont need a new carrier..
Bronco Ollie is offline   Reply With Quote
Old February 4th, 2008, 08:04 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
sink some rods in that "insert racial slur here"
Old February 4th, 2008, 08:08 PM   #7
If you plan on keeping it long term, spool it. Welding is great if you are on a tight budget but you need to make sure you do it right.
Old February 4th, 2008, 08:10 PM   #8
muddywater
muddywater's Avatar
yeah. i haven't had a problem welding my 8.8. i just figured i am only running a 4.0 v6 in my ranger so i dont think i have the power to break anything if weld it. oh just to let ya know im putting the 60 in the rear and the 44 in front they are 3/4 ton axles. a little bit excessive?
Old February 4th, 2008, 08:11 PM   #9
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Weld it. im welded front and rear. Use some 7018 and it will be fine
Old February 4th, 2008, 08:12 PM   #10
fsumotorhead
N8KVB
fsumotorhead's Avatar
Weld it, then if it breaks, buy a spool.
Old February 4th, 2008, 08:34 PM   #11
Bones
Bones's Avatar
weld it
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 4th, 2008, 08:34 PM   #12
junk90xj
ALLPRO AUTO
junk90xj's Avatar
agreed
http://www.apalansing.com/
Old February 4th, 2008, 09:07 PM   #13
thormxboy420
FOUNDRY RATT
thormxboy420's Avatar
Send a message via AIM to thormxboy420
i say weld
thormxboy420 is offline   Reply With Quote
Old February 10th, 2008, 02:20 PM   #14
kkodet
kkodet's Avatar
Weld it, but before you do, heat the spider gears with a torch till they are red hot, then weld the hot metal. I've done it this way and have never had a problem. It insures good weld strength in the hardened gears.
Old February 10th, 2008, 06:04 PM   #15
snohog
Default full spool it
full spool it, welding it is wacky...
snohog is offline   Reply With Quote
Page generated in 0.22608 seconds with 68 queries
