Injector service - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2008, 06:18 PM   #1
Paul04TJ
Small, but talented
Paul04TJ's Avatar
Default Injector service
Any place in Metro Detroit that can service/test fuel injectors?
Paul04TJ is offline   Reply With Quote
Old February 4th, 2008, 06:27 PM   #2
Bones
Bones's Avatar
gas or diesel?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 4th, 2008, 06:36 PM   #3
Paul04TJ
Small, but talented
Paul04TJ's Avatar
I have Gas.
The car burns gas also..........
Where in DB heights are you? I work at Southfield and Ford.
Old February 4th, 2008, 08:19 PM   #4
Bones
Bones's Avatar
ford and telegraph
where do you work?
don't know any local shops that flow test unleaded fuel injectors
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 4th, 2008, 09:18 PM   #5
Paul04TJ
Small, but talented
Paul04TJ's Avatar
I work for IAC. PP's old building.
Old February 4th, 2008, 09:34 PM   #6
Smiley23
Smiley23's Avatar
I have been trying to find the same thing. Bones, do they do ultrasonic cleaning (off the car)?
Smiley23 is offline   Reply With Quote
Old February 5th, 2008, 02:38 PM   #7
Paul04TJ
Small, but talented
Paul04TJ's Avatar
I called Kinsler in Troy. They will tear them down, clean them, replace the screen, rebuild them for $20.90 each.
Much better than $149.00 Murrays want for each replacement.
Old February 5th, 2008, 02:50 PM   #8
Smiley23
Smiley23's Avatar
Definatley a better deal than I was looking at:
http://www.theinjectorperfector.net/gas.html
Old February 5th, 2008, 03:06 PM   #9
Cruzin performance on the west side of the state is one of the best in the country. They'll rebuild and flowtest/balance your injector sets. Cost is not bad at all.
http://www.cruzinperformance.com/
Old February 5th, 2008, 07:40 PM   #10
Smiley23
Smiley23's Avatar
Thx for the info Hag-gar.
Old February 5th, 2008, 10:22 PM   #11
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
x2
I have had several sets flow tested and then flow matched for different motors I have built. I used to do all my chassis dyno pulls there too.
Old February 5th, 2008, 10:28 PM   #12
Mclovin
"The Situation"
Mclovin's Avatar
Find a place that does BG products.. I normally dont beleive in the hype of these "snake oils" but we do this stuff at work and i can honestly say it works good ! Taken cars that were stumbling and running like shit. Run this through the fuel system and it cleans the fuel injection right out and cars ran great ! The kit we use, you shut off the fuel pump and run the car on the product it works great.. IM sure there's a shop down by you that Carries BG Fuel Injector Cleaner.. This kit is done with the fuel system in tact.. no removal
Old February 6th, 2008, 02:03 PM   #13
Paul04TJ
Small, but talented
Paul04TJ's Avatar
Replaced the 02
Found a ground hanging.
freaking Engine to chassis ground.
Fawker runs great now!
No need to clean the injectors.
Page generated in 0.30052 seconds with 61 queries
