Crazy thought. ever been done? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2008, 08:44 AM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default Crazy thought. ever been done?
anyone ever hear of someone taking a dana 60 rear and making it into a dana 60 front? i'm guessing it wouldn't be that hard, but i wonder if anyones ever done it and was successful.
Old February 4th, 2008, 08:48 AM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Why is that crazy? Cut off old tubes, re-tube and weld on outers of your choice no big deal.
Old February 4th, 2008, 08:54 AM   #3
Tab
Tab's Avatar
It can be done however you have to figure out some sort of axle seal in the pumpkin. Fronts have them to keep the oil out of the tubes and rears use the oil to lube the hub bearings. There was a company making a special seal that fits inside the factory diameter of the tubes to convert it but I'm not sure the name or anything.
Old February 4th, 2008, 08:58 AM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
What makes a front Dana 60 more expensive is from the inner-Cs out.
Many people that having the D60 knuckles, spindles, C, etcs. make a 609 by using a 9" center section and the D60 knuckle assembly. This saves some weight and can gain under the diff clearance, and with a Hi-9 (no currie, the real hi-9) it can be stronger.
Old February 4th, 2008, 09:05 AM   #5
beejers
always building
beejers's Avatar
i have even seen 14 bolt fronts.
beejers is offline   Reply With Quote
Old February 4th, 2008, 09:08 AM   #6
steveo
In the band!
its not uncommon, search over at pirate. now what would be cool is a d 35 front end.
Old February 4th, 2008, 09:30 AM   #7
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I had the link to them but that was on my old PC.
Old February 4th, 2008, 09:32 AM   #8
You could get them in a TTB ford...
Exactly, though, as noted above. Sure, you can do it, but as noted, the costs are in the knuckles, hubs, shafts, rotors, etc.
Its more useful when someone is breaking Dana 60 R&Ps, and wanted to go to a 14bolt or Dana 70/80.
Old February 4th, 2008, 09:34 AM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
so basically it wouldn't be any cheaper then. cuz i have a dana 60 FF rear that i plan on using, but in the event i can't locate a 60 front i thought about making it into a front and getting a chevy 14 bolt for the rear.
Old February 4th, 2008, 10:15 AM   #10
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
You never know. If you find someone selling off used C, knuckles, etc. you might be able to build it for cheap.
Or you can buy aftermarket parts from places like solid or spidertrax and build it that way, but that'll cost a few bucks.
Old February 4th, 2008, 10:16 AM   #11
hehehe, just need to find a rusty front 60s with spun carrier bearings or something.....
Old February 4th, 2008, 10:28 AM   #12
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Dana 61 fronts make good outer donors cause not many like messing with them. Steal all the good stuff off of it.
Old February 4th, 2008, 10:46 AM   #13
Bones
Bones's Avatar
you would still have a low pinion D60, with a lot of time and money into it.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 4th, 2008, 01:10 PM   #14
1badzuk
1badzuk's Avatar
it was done in 4wheeler or petersons magazine i belive it was called hazel 60 it was neat for sure
1badzuk is offline   Reply With Quote
Old February 5th, 2008, 10:13 AM   #15
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
x2, i couldnt get much for the dana 61 out of my cummins, and the guy bought it to use the outers for a rear steer axle.
Old February 5th, 2008, 10:58 AM   #16
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Speedway Motors http://www.speedwaymotors.com/ sells internal seals for 9" axles for their full floater racing kits. I dunno where it is on their web site, but I got their catalog the other day and I saw them in there while flipping through it.
Also Mad4wd makes some internal seals that mount at the end of the axle tube, right at the inner-C.
Page generated in 0.30896 seconds with 71 queries
