I got some beadlock rims and humvee rim/runflat info also - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Pictures and Video
Pictures and Video A forum for 4x4 related photos and videos
Old February 7th, 2008, 08:46 PM   #21
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Originally Posted by fukkinrizzo View Post
ahhh. do you just lube them up and stick them in?
I use thick bearing grease and lube the oring, plus it keeps the oring in place.
Originally Posted by silverxj View Post
I have a one track mind.
I've only heard/read of the rubber ones being a PITA to install, so I'm not sure.
On PBB there's a nice write up on cutting the pvc style into halve's that seem to assemble a lot easier.
Stazworks makes a great set of inner beadlocks. They go into the tire very easy and a decent price as well.
Old February 7th, 2008, 08:52 PM   #22
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I think a ratchet strap to compress them would help
Old February 9th, 2008, 09:11 PM   #23
special ed
Pickup Agent
special ed's Avatar
I have some ratchet straps for sale.
Missing some pieces, you can have new ones sent over from T-wahn.
Township says I can't keep them.
I paid $40.00 each for them new.
Selling them for $39.00.
special ed is offline   Reply With Quote
Old February 10th, 2008, 11:20 AM   #24
phazer42
I wheel, therefore I am
phazer42's Avatar
the magnesium runflats are not being used in the current run of Humvees.... they switched over to rubber runflats a while ago, back when they switched the Hmvees from the bias-rated 8-bolt wheels to the radial-rated 12 bolt wheels.... the magnesium ones are actually much easier to deal with then th rubber, easy to install, remove, and much lighter.
The rubber ones suck ass to install into a tire. You have to ratchet the thing into a big oval, basically so that the insides touch each other, then you have to man handle it into the tire, ussually with aid of 1 or more crow-bars.... its a PIA, but once its done ussually its a while before you get to do it again.
If you are looking to get the rubber runflats, you can get them through a hummerdealer for way to much money, or you can find them on e-bay, humvee.net's classified's sometimes, austin aviation's ebay store or just on e-bay ingeneral.... they are not cheap, ussually can be found for 200+ each... from a dealer I think they are like 700 each....
phazer42 is offline   Reply With Quote
Old February 10th, 2008, 01:11 PM   #25
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
I just got a pretty dang good deal on 12 bolt H1's, rubber runflats and tires from www.americanhumvee.com Larry there was excellent to deal with.
12 bolt H1 rims, 37" tires and Rubber runflats weigh in at 160 lbs per tire/wheel combo though.
This has gotten way off topic :tonka:
Old February 10th, 2008, 01:52 PM   #26
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
lots of good info though
fukkinrizzo is offline   Reply With Quote
Old February 14th, 2008, 02:47 PM   #27
rargreen
88
rargreen's Avatar
Got pic's?
rargreen is offline   Reply With Quote
Old February 14th, 2008, 02:50 PM   #28
Salty
Salty's Avatar
Trades?
Salty is offline   Reply With Quote
Page generated in 0.30978 seconds with 46 queries
