EGR valve - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2006, 05:04 PM   #21
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Originally Posted by MuddyPaws
Sorry...forgot about this post. A HEGO is a Heated Exhaust Gas Oxygen sensor...sheesh GM, you should know that Mr. ASE.:tonka:
We just called 'em dem fancy heated sensors.
Old March 29th, 2006, 02:56 AM   #22
noodles
give 'er sh*t ay?
noodles's Avatar
Originally Posted by going-strong
so if i hook up a scan tool, if everything is operating correctly it should start out rich and then swith to lean, and if it is broke it will just start off on lean and stay there?
it should start cycling after couple min of operation. if it doesnt go in to closed loop and not switching from rich to lean, then ya it would just stay in probley one position.
Old April 2nd, 2006, 11:15 PM   #23
user name
keep your stick onthe ice
user name's Avatar
Originally Posted by noodles
caping off the egr will not cause your engine to run crapy, i have done this on mine before and it ran just fine.
what did you use to cap yours?
Old April 6th, 2006, 12:15 PM   #24
noodles
give 'er sh*t ay?
noodles's Avatar
i just got a peice of metal, and some gasket material, and put that in between the manifold and the egr tube. using the old bolts.
Page generated in 0.22772 seconds with 35 queries
