8.8 question???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2008, 04:16 PM   #1
badazzamc
Get Some
badazzamc's Avatar
Default 8.8 question????
I have a 99 xj with 29 spline 8.25 so here is the question I see a lot of 8.8's with disk brakes and lsd for a good price. So would it be worth swapping the 8.25 for a 8.8? How do they compare in strength? Is the width close? It seems a lot cheaper to go this rout rather than buying a locker for a 8.25 since my selection is very limited. Any thoughts on this would be great. Thanks
Old January 29th, 2008, 04:27 PM   #2
bryanbryan89x
bryanbryan89x's Avatar
I did that swap and thought it was well worth it. I think the 8.8 was 5/8'' narrower than the 8.25. The one thing I really liked about it was it was a flat flange yoke, instead of U-joint straps. I kept busting those 1/4'' bolts on that pinion yoke.
bryanbryan89x is offline   Reply With Quote
Old January 29th, 2008, 04:42 PM   #3
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
To me it's worht the extra.
Larger ring gear.
More slection of ratio's. I wanted a 4.88 and the 8.25 only goes up to 4.56.
2 more splines.I wanted a non c-clip axle with chromo shafts and I can do that with the 8.8 and not the 8.25. I'll also add a little more width to the back.
Rear disc brakes are far better than the drums on the 8.25. Have you priced out how much it is to convert a 8.25 to disc.
I'm doing away with the lower shock mounts that hang down and snag shit. With the T&T U-bolt elems.
Old January 29th, 2008, 05:41 PM   #4
badazzamc
Get Some
badazzamc's Avatar
what are you doing about the driveshaft, since the 8.8 has a flange?
Old January 29th, 2008, 07:50 PM   #5
ddeadserious
ddeadserious's Avatar
you get one of these:
http://www.amazon.com/MORE-221379-Yo.../dp/B000FQ1WHY
ddeadserious is offline   Reply With Quote
Old January 29th, 2008, 08:11 PM   #6
badazzamc
Get Some
badazzamc's Avatar
ok thanks I figured there was something like that I just didnt know what it was called.
Old January 29th, 2008, 08:14 PM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
Hey trav, i have one, it's for a fullsize, but would probably work.
Free too
Old January 29th, 2008, 08:34 PM   #8
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Originally Posted by ddeadserious View Post
Originally Posted by Mongo View Post
source for 8.8 flange
bigger u-joint (1310) 2-2-1369
smaller u-joint 2-2-1379
Weller Truck Parts
Grand Rapids
800-872-6697
Website wont do you any good just call and ask for sales.
$12.41 for 2-2-1369, the other should be close. + shipping.
Way cheaper than the rip off at MORE. Only thing I would buy to swap it in from them is the parking brake cables.
Old January 29th, 2008, 08:49 PM   #9
kickstand
circling the drain
kickstand's Avatar
could someone suggest how a dummy like me can determine if I have the bigger or smaller u joint?
I have a tom woods CV shaft, i am assuming i have the bigger u joints. but I have no clue really.
Old January 29th, 2008, 08:53 PM   #10
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Cap Dia Width Series
1-1/8" 3-1/4" 1310
1-1/8" 3-5/8" 1330
1-3/16" 3-5/8" 1350
1-3/16" 4-3/16" 1410
Old January 29th, 2008, 09:17 PM   #11
kickstand
circling the drain
kickstand's Avatar
1-1/8" 3-1/4" 1310
1-1/8" 3-5/8" 1330
1-3/16" 3-5/8" 1350
Thank you.
Old January 29th, 2008, 09:38 PM   #12
Pete M
Comanche Addict
Pete M's Avatar
Free too
Unfortunately it'll only work if he has a matching fullsize front axle. The fullsize axles are much wider and have a 5 on 5.5 bolt pattern. It's the Explorer axle that matches the Dana 30.
--Pete
Pete M is offline   Reply With Quote
Old January 29th, 2008, 10:16 PM   #13
fsumotorhead
N8KVB
I meant the flange adapter!
Old January 29th, 2008, 10:35 PM   #14
Pete M
Comanche Addict
Pete M's Avatar
Oh, well then it'll bolt to any 8.8 just fine of course. You'll just need to measure for the U-joint.
--Pete
Old January 30th, 2008, 06:58 AM   #15
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
So, when getting an 8.8 from the junk yard, we should try to get the drive shaft (or atleast the rear adaptor) as well??
I would think we might want the rear brake line and emergency cables as well??
RIP FULLSIZE4LIFE
Old January 30th, 2008, 01:51 PM   #16
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
All depends on you application. Exploders are 1330 u-joints. You could get a 1310/1330 combo joint though.
I would not reuse the brake lines for safety reasons. I bought a set of braided SS lines.
The emergency cables are more than likely to short.
Old January 30th, 2008, 01:54 PM   #17
kickstand
circling the drain
kickstand's Avatar
rocks where did you get your lines and how much did they run you?
Old January 30th, 2008, 01:59 PM   #18
Pete M
Comanche Addict
Pete M's Avatar
To add to what Rocky said, most Jeeps run a 1310 (I think Aerostars and rangers have that size flange adapter, but I'm not 100%). Be careful when hunting for flange adapters under Aeros, rangers, mustangs, Crown vics etc, that you're looking at an 8.8 and not the smaller 7.5 axle (or whatever number designation it is).
The rear rubber brake line is only $15 brand new so it's not a big deal to save yourself some time and cut it. Then you don't have to worry if it's good or not. Most Explorer axles I've seen needed new hard lines. For E-brake cables you might be able to use your current ones and do as the owner of the Jeep pictured below did. He just wrapped the cable around the E-brake lever and secured it with a cable clamp.
--Pete
Old January 30th, 2008, 02:01 PM   #19
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Summit racing. They weren't cheap.
RUS-641291 Fittings, Brake, Steel, Nickel Plated, Male -3 AN to Female 3/ 8 in.x 24-Thread, Pair
$15.95
RUS-657022 Brake Line, Braided Stainless Steel Hose, 10mm Banjo to Straight -3 AN Female, 12 in. Long, Each
$26.95
Polyperformance has a set to but they are only 9" long. The plus side is they are cheaper.
I also ordered a SS ARB line kit, no POS blue plastic here. 12 foot long with both fittings.
RUS-634520 Brake Hydraulic Line; Air Locker Line Kit; Braided Stainless Steel; 12 ft.; w/ -3 Coupling Nuts On Both Ends
$67.99
Old February 1st, 2008, 10:19 AM   #20
kickstand
circling the drain
kickstand's Avatar
I got my adapter from Unlimited offroad Centers in Fenton Michigan yesterday.
Thanks guys.
FYI they have a couple on hand and in stock.
$25.
Page generated in 0.82900 seconds with 83 queries
