Turbo YJ project - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2008, 08:17 PM   #21
Bones
Bones's Avatar
Originally Posted by Mike Hancho View Post
that shouldn't have any real effect on spool rate as all the exhaust energy is still directed at the turbine....they make rear mount turbos for cars and such...
oh boy....
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 11th, 2008, 09:27 PM   #22
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
STS makes turbos that mount at the rear of the vehicle.They make great power. http://www.ststurbo.com/
You would think they would have a ton of lag, but they don't. I am only hoping for 4.0L type power out of this too. I am not trying to make a hot rod. Hopefully i'll have it running by the weekend.
Old February 11th, 2008, 10:20 PM   #23
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
can't wait to see it done
Bronco Ollie is offline   Reply With Quote
Old February 11th, 2008, 11:17 PM   #24
DSM
I can has terrain?
DSM's Avatar
Send a message via AIM to DSM
Damn... that is the most hack job turbo set up i've ever seen... and i've seen some pretty fucked up set ups...
DSM is offline   Reply With Quote
Old February 11th, 2008, 11:23 PM   #25
Rob the plumber
I never said it was pretty dickhead, but thanks for the input. Go back to Xceedspeed.
Old February 12th, 2008, 09:26 AM   #26
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
They do have lag - look at how the power doesn't really happen on the dyno charts before 3500-4000 rpm. Looks great for peak power, but I don't think that would work well wheeling in a Jeep.
@clarkstoncracker
Old February 12th, 2008, 01:31 PM   #27
Mulder
Jeeper
Mulder's Avatar
What type of sensors are required integrating a turbo into the fuel injected Jeep.
Can you still use the Jeep ECU for injector timing? Does the MAP sensor read boost as well as intake vaccum?
Mulder is offline   Reply With Quote
Old February 12th, 2008, 11:38 PM   #28
Rob the plumber
The stock MAP does not recognize boost. It will peg at zero vacuum, putting out the maximum 5 volts to the ecm. So basically I think I will need to trick the computer into adding more fuel. An FMU will raise fuel pressure based on boost, and the ecm will command the same pulse width to the injectors. Since the fuel pressure is higher, more fuel will be sprayed from the injectors.
Actually, for all I know, the MAP sensor may freak out if it sees boost. I have seen check valves to keep the map from seeing positive pressure.
Old February 12th, 2008, 11:40 PM   #29
Rob the plumber
You have a good point there. Good for drag racing I guess.
Old February 13th, 2008, 09:36 AM   #30
jared
Can't Worry About It
jared's Avatar
www.homemadeturbo.com its mostly honda stuff, but the same principles apply
jared is offline   Reply With Quote
Old February 13th, 2008, 12:50 PM   #31
Mulder
Jeeper
Mulder's Avatar
You could easly make a voltage divider that sends the 0-5V signal to the ECU based off the boost pressure.
Then you could use an adjustable resistor to dial in the specific injector pulse width. See the attached schematic.
I believe the MAP sends out 0.5V to 4.5V anything out of this range is considered to be an error. So depending on your Boost pressure gauge you can choose the right resistor.
In my schematic I have a 0-100 ohm sensor so you'd want around a 10 ohm resistor with it. For different resistive rating psi sensors you'll use different resistors.
If you give me the resistance rating I'll help ya out.
Old February 13th, 2008, 01:07 PM   #32
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
Good luck with it Rob, looks good so far. And F that dsm dude.
SlayerXJ is offline   Reply With Quote
Old February 13th, 2008, 02:58 PM   #33
Watson
Newb!
Watson's Avatar
By far one of my favorite rig projects on here.
Watson is offline   Reply With Quote
Old February 13th, 2008, 05:43 PM   #34
Rob the plumber
Thanks for the support.
Mulder,
I am not completely grasping what you are explaining. What would you need the resistance rating of?
Old February 14th, 2008, 07:29 AM   #35
SinisterX
I Drank WHAT!
SinisterX's Avatar
Send a message via MSN to SinisterX
You'd be better off switch over to a mass air flow system instead of the speed density. The ECM will go into default once the MAP input goes out of range. The default inputs will be throttle angle (TPS) and RPM, then the ECM will look at the fuel table program and quess how much injector pulse width to use. Nowhere in that table are calculations for boost. Not saying it can't be done, but it would be a hell of a lot easier with a MAF system.
SinisterX is offline   Reply With Quote
Old February 14th, 2008, 03:12 PM   #36
smasheromalley
smasheromalley's Avatar
Just a comment, If you have the time oxy/acetylene can make some really nice welds on cheap exhaust pipe. I suppose you could probably braze it too, especially when this is just for mock up/tuning.
neat project =)
Old February 14th, 2008, 05:50 PM   #37
got mud ratt
Junk Yard Fab
got mud ratt's Avatar
Default turbo power
Sweet rig but will the turbo give you the power you need. What kind of power and torque increase do you think you are gaining.
got mud ratt is offline   Reply With Quote
Old February 14th, 2008, 09:30 PM   #38
Rob the plumber
Mass air is definitely more adaptable, but converting it would probably be an expensive pain in the ass. Turbo's also like to use a blow through meter instead of the typical draw through. It would require a lot of tuning to get driveability where you want it.
The import crowd turbocharge speed density Hondas all the time. A check valve for the MAP sensor will keep it from seeing boost, and an FMU will add the extra fuel. I'll run premuim fuel and hope the factory timing is not too aggressive.
How much power do I expect? Not much. :) It will be a crudely tuned and installed low boost turbo on a 2.5L that is trying to drag 3400 lbs down the freeway. I will be happy if it has good driveability and makes enough power to do 70 mph without having the throttle 3/4 down. I don't see why 60-70 horsepower and 80 ft-lbs would be out of the question though.
Old February 14th, 2008, 11:04 PM   #39
donleybrent
donleybrent's Avatar
I love it. I however would have went straight to the 360. lol
donleybrent is offline   Reply With Quote
Old February 14th, 2008, 11:43 PM   #40
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
You could easily switch over to a 2.5 bar MAP for turbos.
Page generated in 0.46388 seconds with 84 queries
