2 10" mtx 5500 and 800 watt ma audio amp - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2008, 09:45 PM   #1
thehawiianpunch
lift it...
thehawiianpunch's Avatar
Send a message via AIM to thehawiianpunch
Default 2 10" mtx 5500 and 800 watt ma audio amp
i have 2 10" mtx 5500 in a sealed box made to factory specs. subs like new only reason im gettin rid of them is because i had 4 10" in my xj and besides rattling everything to death it was just way too loud plus all i listen to is country. ill sell just the subs $150 or with a 800 watt ma audio hk798 all together for $300
Sensitivity: 90.8 dB
RMS Power Range : 300 Watts
Peak Power Handling: 600 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 36 Hz
High Frequency Response: 150 Hz
Diameter: 10 Inch
Asymmetrical Linear Drive Technology
Aluminum Deposition, Carbon Filled Cone
New Concave Dust Cap / Cone Assembly
Spider Plateau Venting
Folded-Window 16 Gauge Steel Frame
Stitched Nitrile Butadiene Rubber (NBR) Surround
60 oz. Strontium-Ferrite Magnet with Protective Magnet Boot
1 3/4" Aluminum Voice Coil
428°F Voice Coil Wire Temp Rating
Injection-Molded Polystyrene Gasket
Radius Vented Pole Piece
Woven Tinsel Leads
Xmax: 0.53"
Mounting Depth: 6.2"
thehawiianpunch is offline   Reply With Quote
Old January 28th, 2008, 10:57 PM   #2
thehawiianpunch
lift it...
anybody?
Old January 28th, 2008, 11:02 PM   #3
thehawiianpunch
lift it...
subs retail ~$130 each
amp ~$200
in a box ready to go
Old February 11th, 2008, 07:00 PM   #4
thehawiianpunch
lift it...
bump
Page generated in 0.20414 seconds with 35 queries
