8.8 in place of D35... ride heigth problem.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2008, 05:49 PM   #1
gtmgooser
gtmgooser's Avatar
Default 8.8 in place of D35... ride heigth problem....
Guys I need some help with solving a ride height problem with my 87 YJ. I am installing an 8.8 in place of the stock D35 and due to the larger tube diameter of the 8.8, I know have a rear end low rider. Other than doing a spring over, is there anything else that can be done to get the ride heigth back to at least where it was prior to the swap? What have all you others with 8.8's in YJ's done?
gtmgooser is offline   Reply With Quote
Old January 27th, 2008, 06:27 PM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
taller springs or a longer shackle.
Old January 27th, 2008, 09:31 PM   #3
PavementPounder
PavementPounder's Avatar
I would do the shackle on the rear, or add a bumper/winch to the front. The difference in height you're talking about won't even be noticeable to people unless they are really looking for it.
Old January 27th, 2008, 11:09 PM   #4
sodapop
Support the Sport!
sodapop's Avatar
Just own it man. If you act like you wanted it that way, people will think it's cool.
but if you're still set on a different ride set up then:
A little long shackle in the rear would help, weight on the front like PP said, A thin block on the front.
I didn't do anything with mine when Iput the 8.8 in.
Old January 28th, 2008, 05:36 AM   #5
PavementPounder
That's not what I mean (edited my post).
Old January 28th, 2008, 05:48 AM   #6
JEEPR
Playing Possum
JEEPR's Avatar
Originally Posted by PavementPounder View Post
a very thin block on the rear
A lift block between the rear axle and spring on a spring under axle will lower the vehicle. Blocks on the front are bad. :miff:
Either get the spring re-arched at a spring shop for slightly more lift or a longer rear shackle.
JEEPR is offline   Reply With Quote
Old January 28th, 2008, 05:58 AM   #7
PavementPounder
Goddam it. That is what I was thinking since it would bring the front down equally, but I would never put any kind of block in the front. Took that out completely.
No more early posting. I'm going to work now.
Old January 29th, 2008, 01:09 AM   #8
jeepguy74
jeepguy74's Avatar
i put a 1 inch longer shackle in the rear and it took care of it for my aplication but it wasnt really a problem for me
Page generated in 0.23128 seconds with 47 queries
