Another Dana 30 ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2008, 06:14 PM   #1
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
Default Another Dana 30 ??
I don't know if it has been asked or not, couldn't find it in the search.
Exactly what is the difference in D30's I know XJ, YJ, TJ are the same. But what is the difference between these and the older CJ style other then lock outs and they swapped sides? Aren't they basically the same axle? Why does everyone seem to hate the newer ones in relation to the older? Are the axle shafts and joints stronger in the older ones? How bout the ring and pinion, are they stronger? Just something I was curious on, seems everyone wants to get rid of them on the newer rigs but they still run them in the older ones. Thanks for helping me clear up my head!
71jeepster is offline   Reply With Quote
Old January 26th, 2008, 06:30 PM   #2
kickstand
circling the drain
kickstand's Avatar
yj, tj and xj are not the same.
some have the smaller ujoints, some have the bigger ujoints. Some have 2 peice shafts on the long side, some have one peice shafts on the long side.
some are high pinion, some are low pinion.
In my opinion I think a lot of people are quick to rid themselves of the dana 30 when it really is not "THAT" bad of an axle as long as you understand what you are working with.
It has the same size ujoints as a dana 44. (if you have the big ujoints)
In my experiences with a dana 30 on a tj and a yj both on 33-35" tires the weak links on the newer axles seem to be the u joints, shafts, and ball joints/knuckles. I have never broken the pinion or ring gear, nor spiders. I am sure it could happen, but I have been lucky enough to not have it happen yet.
Currently I have 3 complete dana 30's as spares for my jeep. I carry the axle shafts with the unit bearings already on them for a quick swap. I also carry an extra knuckle with the ball joints in it in case of a balljoint/knuckle problem.
I dont know much about the older dana 30's
Old January 26th, 2008, 06:38 PM   #3
71jeepster
71jeepster's Avatar
I knew that they had different joints and high and low pinion but they are still essentially the same, I just wasn't sure what makes the older ones "better". My XJ has the older joints right now, I'm sure when I break them I will put the larger ones in. Maybe it's just a case of someone who only used the skinny pedal and not his head in conjunction with it? I'm sure mine will hold up for a while, it has to my wife still uses it as a DD, but I was just thinking for future plans
Old January 26th, 2008, 06:43 PM   #4
kickstand
circling the drain
kickstand's Avatar
I will be running 36's. I like the skinny pedal. I will report back to you on how often I brake, what brakes, why it broke and what I was doing to cause it for you.
Old January 26th, 2008, 06:46 PM   #5
71jeepster
71jeepster's Avatar
Cool thanks, I'm only gonna be running 265/75/16 and 3.5 to 4 inches of lift, so I should be ok
Oh, I love your dog!! Malamute or Husky?
Old January 26th, 2008, 06:47 PM   #6
kickstand
circling the drain
kickstand's Avatar
ahhh yes you will be more then fine :tonka:
Siberian husky, she is 5 yrs old.
Old January 26th, 2008, 07:18 PM   #7
Pre4runner
Bike Dude
Pre4runner's Avatar
I'm on 36" with my HP 30 locked, we'll see how it does
Old January 26th, 2008, 07:23 PM   #8
71jeepster
71jeepster's Avatar
That's good to know, I really shouldn't have any problems then!
Old January 26th, 2008, 07:33 PM   #9
71jeepster
71jeepster's Avatar
Here's a pic of ours. Siberian Husky, Alaskan Malamute mix. He weighs about 100 lbs and loves to run!
Old January 26th, 2008, 07:39 PM   #10
kickstand
circling the drain
kickstand's Avatar
yeah the malamutes are a lot bigger, my ole girl is only 45 lbs, but she can run like no other lol
Old January 26th, 2008, 07:46 PM   #11
71jeepster
71jeepster's Avatar
yeah, it's nice rollerblading with him, All I have to do is hold on! lol
Old January 26th, 2008, 07:52 PM   #12
kickstand
circling the drain
kickstand's Avatar
Started mine in a sled dog harness at 3 months witht he mountain bike
she runs free in the woods when we ride, but on a leash in town of course and she can tow me on my bike and my son behind us in his burley bee cart for miles.
It's great.
Old January 26th, 2008, 08:00 PM   #13
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
New= uni bearings and weaker ball joints
Old= serviceable bearings, dana 44 ball joints and able to use lockouts. All LP.
I took the best of both new and old and built the ultimate 30.
And pulling it for a ultimate hp 44 :miff:
Old January 26th, 2008, 08:05 PM   #14
kickstand
circling the drain
kickstand's Avatar
So you polished one turd to replace it with another polished turd ? :tonka:
Old January 26th, 2008, 08:15 PM   #15
71jeepster
71jeepster's Avatar
I saw your write up on that, that would be sweet but definitely not necessary for a DD and ocasional wheeling trip. I have a feeling my smaller u-joint's are gonna fail pretty quick though, the terrain out here is a lot different then MI.
Exactly how much better are the serviceable bearings, and why are they better? When they go bad they need replaced just like the unit bearings right?
Old January 26th, 2008, 08:28 PM   #16
Jeepaholic
Jeepaholic's Avatar
The second polished turd is frickin' sweet though.
Lockouts are nice on a DD though
like $30 dollars a side compared to ?? (never bought a uni bearing )
Plus if you keep them greased they will last a long time.
Old January 26th, 2008, 08:30 PM   #17
kickstand
circling the drain
kickstand's Avatar
i dont doubt its cool, just a lotta work
Old January 26th, 2008, 08:35 PM   #18
71jeepster
71jeepster's Avatar
yeah the lockouts would definitely be nice! I'm not sure how much a unibearing is, but they come out easy and no where's near all the grease! lol
Old January 26th, 2008, 08:36 PM   #19
71jeepster
71jeepster's Avatar
yes it is!!! So who's gonna be the lucky new owner?
Old January 26th, 2008, 08:38 PM   #20
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
uni bearings are like $125-$175
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Page generated in 0.44538 seconds with 84 queries
