Contact pattern check round 5 and final - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2008, 04:53 PM   #1
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Default Contact pattern check round 5 and final
Seems ok to me but what do I know. It's my first time setting gears. Just need to double check.
ID:	19889   Click image for larger version
Old January 25th, 2008, 04:56 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
from the blurry pictures it looks ok to me. hows the backlash?
Old January 25th, 2008, 04:58 PM   #3
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
.007"-.008"
Old January 25th, 2008, 04:59 PM   #4
silverxj
Recovering XJ owner
silverxj's Avatar
.008 is the most you want ... anything more is considered excessive.
Old January 25th, 2008, 05:03 PM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I guess I'll take out .002" on the pinion side and add it to the ring gear side. Then try again.
Old January 25th, 2008, 05:08 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
looks close to the edge of the the tooth?
Old January 25th, 2008, 05:11 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
.008 is the upper limit .002 taken out should be perfect.
Old January 25th, 2008, 05:14 PM   #8
badazzamc
Get Some
badazzamc's Avatar
iagree it looks a little close to me. i would try and center it
Old January 25th, 2008, 06:04 PM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Shallow.... at .005 and try again.
JcrOffroad
Zoom Zoom!
Old January 25th, 2008, 06:52 PM   #10
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I'll knock out the inner pinion bearing race and remove .005" tomarrow. Then start over. Yeah me.
Old January 27th, 2008, 01:16 PM   #11
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I am I correct in thinking that the pinion is still to close to the ring gear centerline? I chould remove another .005" from behind the inner race and try again. TIA
Drive
Coast
ID:	19994   Click image for larger version
Old January 27th, 2008, 01:48 PM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Can you take a better picture? It's hard for me to tell.
If it had to guess from the drive side I would say your pinion depth is good, and maybe adjust your backlast a little to center the pattern on the tooth.
JcrOffroad
Zoom Zoom!
Old January 27th, 2008, 02:28 PM   #13
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Added .002 to the pinion side. Backlash .005"
drive
Coast
ID:	20013   Click image for larger version
Old January 27th, 2008, 04:25 PM   #14
sodapop
Support the Sport!
sodapop's Avatar
Maybe try to add 3.2 MP to the Camera and retake the pictures:tonka:
It is really hard to tell from those pics though. It might help if you don't have your camera so close when you shoot the pic. You might be inside the focus range.
Old January 27th, 2008, 04:38 PM   #15
TechJeeper
Formerly "Gr8archer"
TechJeeper's Avatar
Send a message via AIM to TechJeeper
MACRO PLEASE! Look for the little Flower icon on your camera.
TechJeeper is offline   Reply With Quote
Old January 27th, 2008, 05:04 PM   #16
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Drive
Coast
Not only do I suck and R&P installs and do with a camera to. Thanks
ID:	20018   Click image for larger version
Old January 27th, 2008, 05:23 PM   #17
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yea your too close to the ring gear center. put the pinion alittle farther away recheck backlash and you should be good.
Old January 27th, 2008, 05:38 PM   #18
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Well if I do that the pattern gets to closer to the toe on drive side.
Old January 27th, 2008, 06:30 PM   #19
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I don't think I can get it any better than this. .005" backlash
Drive
Coast
ID:	20020   Click image for larger version
Old January 27th, 2008, 06:33 PM   #20
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
the coast side you mean? coast side doesn't matter as much as the drive side. you want it in the center on the drive side and where ever it ends up on the coast side should be good. unless it's on the very edge of the gear, then you have something else going on.
Page generated in 0.41469 seconds with 84 queries
