chains - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 24th, 2008, 10:26 AM   #1
bigblue2230
still goin
bigblue2230's Avatar
Default chains
ok, so I just got a 2000 cr250. It is in great shape, but will probably need a new chain this spring. (the old one is stretched pretty good.)
My question is, what type of chain should I be using. I know there are several types out there, but I do not know the benefits or cons of any of these.
Please, someone school me on bike chains.
bigblue2230 is offline   Reply With Quote
Old January 24th, 2008, 11:15 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
the 2 types i'm aware of are o-ring and non o-ring. i've used o-ring chains on the few bikes i have had.
maybe this article i found will give some insight
Most stock bikes are equipped with an O-ring chain, and are endless-there is no link to split the chain for removal, and it has to be "broken." Replacement chains generally utilize either a rivet-type link, which must have the pin ends peened for assembly, or a clip-type link. A rivet link is generally stronger and less likely to come apart on its own, whereas a clip link is easier to assemble/disassemble but may come undone. If you use a clip link, safety wire around the sideplate and clip to hold it on, or use a dab of silicone sealant on the clip.
An O-ring chain employs tiny rubber seals between each plate and roller to keep the chain permanently lubricated. While it does add weight, this style of chain lasts longer and requires less maintenance than a non O-ring chain. The small seals may seem to add friction also, but once in use the grease thins out due to the induced heat, and an O-ring chain may spin as freely as a non O-ring unit.
Both styles, however, need periodic lubrication. The non O-ring variety more so-the O-ring type only displaces water and stops the outer surfaces from rusting. Use the appropriate type of lube-some spray-on types may damage the rubber O-rings-and oil your chain immediately following a ride. This will give the maximum amount of time for the oil to soak in. Always apply the lubricant from the inside of the chain, because centrifugal force will help the oil penetrate, rather than fling it on your tire.
This article was originally published in the August 2000 issue of Sport Rider.
Kodiak450r is online now   Reply With Quote
Old January 24th, 2008, 11:22 AM   #3
steveo
In the band!
yeah, the o ring ones re the best. my banshee had a aftermarket one on it when i bought it, and it had it on it when i sold it.
Old January 24th, 2008, 07:09 PM   #4
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Yeah a standard 520 O-Ring chain is the best. Only racers with money still use non O-ring chains.
Get a good name chain when you buy one. The cheap ones have been known to snap easily.
Old January 24th, 2008, 07:40 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Also, do a search on how to check your sprockets - you should replace the front one no matter what, and the rear one if it is worn.
Worn out sprockets will kill your new chain.
@clarkstoncracker
Old January 24th, 2008, 09:17 PM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
I got four years of hard use out of my stock o-ring chain on my banshee, thats pretty good.
Old January 27th, 2008, 05:56 PM   #7
screamer25cc
screamer25cc's Avatar
I would by the 2 sprockets and the chain all at once, That way you know everything is in working order...I have bought several of these off ebay....They have not failed once...
screamer25cc is offline   Reply With Quote
Old January 27th, 2008, 08:19 PM   #8
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
o ring chains are for people who dont know what maintenance is. get a good non oring chain, like a did or something. should be about 60 bucks. for what a sprocket costs, replace that too. every time you are done riding lube the chain. it will last forever.
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old January 27th, 2008, 09:12 PM   #9
jeepguy74
jeepguy74's Avatar
renthal or did is what i run and have never had any problems..now if it is time for new chain then it is also time for new sprokets ....
Page generated in 0.28057 seconds with 50 queries
