Furnace problem, help! - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2008, 06:11 PM   #21
shawn
Resident HVAC/R Jambi
shawn's Avatar
Originally Posted by Apeman View Post
Is the flame sensor a short maybe 1 1/2" or so long piece of metal by the burner?
Yes, it will have one wore going ot it and usually have one screw holding it down, on teh opposite side foteh ignitor.
The pics that are posted is of a pilot sonsor (thermal couple), you DO NOT have one on your furnace if you have an electronic ignition system.
Old January 23rd, 2008, 06:25 PM   #22
mpwal099
Stick it up your ass
mpwal099's Avatar
Going with a different thought here. Does your gas meter have a cover on it? If no, go check it and see if it is iced over. Problem may be the air valve all iced up on it.
mpwal099 is offline   Reply With Quote
Old January 23rd, 2008, 06:46 PM   #23
ElDeeder
I just pulled the Flame sensor and cleaned it with some 220 grit sandpaper. Didn't look that dirty, but I put it back in and it fired up. For some reason I don't think that is going to be the fix, I feel there is something still wrong. I'm going to let it run till it warms up in here a little bit and then shut it down and fire it back up and see what happens. The furnace started acting up on Monday, sometimes it would run, sometimes the flame would be on, others times it wouldn't. The tstat would be set at 67 and it would be at 60, if i switched the tstat to off and then back to auto, it would kick on sometimes with flame, sometimes no flame. Thanks for all the suggestions, i'll keep you guys posted.
Chris
BTW the gas meter does have a cover on it. Thanks for the thought though!
Anyone know if its hard to put a new Tstat in? I thought the problem might have been that so I picked one up today. I wanted a programable one anyhow. I don't have a/c just a furnace. Any ideas has to how many wires?
ElDeeder is offline   Reply With Quote
Old January 23rd, 2008, 08:22 PM   #24
shawn
shawn's Avatar
Could be 2 wires, could be 3. It's not hard to do, just follow the instructions and make srue the stat is set up for the type of heat you have (ie gas/electric, forced air/hot water).
220 grit is a bit harsh for that sensor, I usually use fine steel wool. And, they never look dirty but it's usually the problem. But pick yourself up a new one if you like, they are like $15.
If you think it is the stat, then pull off the stat, if it is a 2 wire stat then just put the 2 wires together and see if that fixes the problem (it should continue to run until you desconnect the 2 wires).
Old January 24th, 2008, 06:58 AM   #25
Harley
HVAC Contractor
Harley's Avatar
Shawn has you rolling down the right track. Definitely is the flame sensor. Steel wool, or a scotch bright pad, are the way to go. I really don't see where this would be in you t-stat.
Harley is offline   Reply With Quote
Old January 24th, 2008, 08:07 AM   #26
ElDeeder
Thanks for everyones help. The furnace was still working this morning. I did end up replacing the T-stat, I wanted a programmable one anyhow. It was only 2 wires, a W and an R wire if i recall. Programmed it and has been working great.
Thanks again to everyone,
Chris
Page generated in 0.33575 seconds with 40 queries
