towing in OD with a diesel - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2008, 08:29 PM   #21
Smiley23
Smiley23's Avatar
Originally Posted by UP_ROKTOY View Post
wow, smiley you are retarded.
And you are not ?
Smiley23 is offline   Reply With Quote
Old January 26th, 2008, 09:13 PM   #22
IDIeselman
IDIeselman's Avatar
I hope I don't offend you boy's as I refuse to read the last 6 post's or so because I have had much drink and it makes me dizzy. But being the highly coveted 7.3 IDI turbo E4od/4.10 the cruising speed (well mine anyhow) @65MPH is about 2250 RPM's The sweet spot as we say For the Indirect injected diesel. (not gasser) So pulling the load in question the only time it will drop from OD is on a substantial grade and the throttle position determines the downshift so if it would down shift it will be at approx 3/4 throttle and needs the lower gear to pull the hill. I completly agree that heat is the #1 enemy of any trans and in this weather when the fan clutch kick's in at 198*engine temp it will be plenty of cooling through the factory cooler. That being said go buy the biggest tranny cooler you can find at put it to good use. I sure hope I don't read this in the morning and think.....WTF was I typing
Old January 26th, 2008, 09:30 PM   #23
sledder
2257 Compliant
sledder's Avatar
99 7.3 Powerstroke, 3.73s. Tow everything from a car hauler to 10,000-pound travel trailer in overdrive. Rule of thumb, if you are under 55 mph lock it out or if you are climbing a hill lock it out. Another rule of thumb, stay over 75 mph and don’t worry about shifting out of overdrive. I think the key is don’t let the trans “hunt” or shift back and forth between 3rd and 4th.
sledder is offline   Reply With Quote
Old January 26th, 2008, 09:34 PM   #24
kickstand
circling the drain
kickstand's Avatar
You made perfect sense. and I agree with you.
Old January 26th, 2008, 09:35 PM   #25
kickstand
circling the drain
kickstand's Avatar
agreed.
Old January 28th, 2008, 10:16 AM   #26
caveman
GeoDude
caveman's Avatar
wow! didn't want to start a pissing match here. IDI, thanks! i'll go check out that site, oh yeah it's only got 135xxx on the clock
Old January 28th, 2008, 03:49 PM   #27
bigNATE®
Cummins WiZzard
Send a message via AIM to bigNATE®
98 Ram 3500 with a 12 valve cummins is my tow rig and on the freeway it stays in overdrive with the converter locked. no problems yet even towing 13,000# of forklift batteries
bigNATE® is offline   Reply With Quote
Old January 29th, 2008, 06:47 AM   #28
groundhog
groundhog's Avatar
you got to love this place. The guy ask for advice and you guys turn it into pissing contest of who thinks they know more.
Good luck Caveman
groundhog is offline   Reply With Quote
Old January 29th, 2008, 06:51 AM   #29
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Old January 29th, 2008, 07:03 AM   #30
groundhog
groundhog's Avatar
Originally Posted by GreaseMonkey View Post
Thats what I was thinking
Old January 29th, 2008, 09:51 AM   #31
Smiley23
Smiley23's Avatar
Good luck Caveman
I hear ya. There are certain people here that just dont want anyone to post a second opinion. They are SMART.
For the record, I am not the one starting the crap! (ie. I didnt make the first slam).
Old January 29th, 2008, 10:00 AM   #32
Grassman
2jz specialist
Grassman's Avatar
so in summation:
towing in OD is OK, just be careful. keep an eye on the temp, and be smart with your foot. nuf said?
besides OD is just another gear right?
Old January 29th, 2008, 10:02 AM   #33
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Grassman View Post
so in summation:
yep
Old January 29th, 2008, 12:04 PM   #34
Sol Goode
Obama Nation!
Sol Goode's Avatar
yep
WRONG!!!
Grandman said if you do it you are stupid
#YOLO
#meballsohard
Sol Goode is offline   Reply With Quote
Old January 29th, 2008, 12:13 PM   #35
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Sol Goode View Post
WRONG!!!
WRONG well ok maybe your right.
Grassman I would say in most cases that yes what you said is right but there ARE exceptions to that rule.
Old January 29th, 2008, 07:47 PM   #36
Grassman
2jz specialist
Grassman's Avatar
always
Old January 31st, 2008, 11:27 AM   #37
bearlys2005
bearlys2005's Avatar
I have an 02 SD Powerstroke 7.3, 3.73 gears and it has some mod's done to it. I was pulling 10,000+ in OD and I thought it pulled great. well it took about 400 miles but OD went out. At that point I had the trans re-built with all the upgrades to make it bullet proof. No problem since, it's a great truck for pulling. If I was that heavy again I would run with overdrive off. I do have a trans temp gage and when OD went out the trans temp was just fine. With your gear it might be easier on it... Good luck
bearlys2005 is offline   Reply With Quote
Old January 31st, 2008, 12:07 PM   #38
smasheromalley
smasheromalley's Avatar
x2
IMO only use OD after you have reached your hiway cruising speed
Old January 31st, 2008, 10:44 PM   #39
groundhog
groundhog's Avatar
WRONG!!!
:chiefwoohaw::chiefwoohaw::chiefwoohaw:
Page generated in 0.48136 seconds with 80 queries
