Dana 35 - how much play - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2008, 09:59 AM   #1
bhunt
BigBri
bhunt's Avatar
Default Dana 35 - how much play
Too cold to be old side yesterday so I was check brakes and such on my '97 TJ. Its stock D 35 with 3.07 and 113,000 miles, only upgrade has been Lock Right Locker. Its a 6 cyl with 32" tires. I noticed some play in the rear differential. I had put tape mark on top of drum to verify my axle ratio and noticed I can twist axle back and forth moving mark 1/2" in each direction before engaging with driveshaft.
When changed fluid in spring found no metal shavings or debri, noticed no missing teeth.
How much play is acceptable? Or am I already on borrowed time?
I would love to swap in D 44 with 4.10 but just can't afford right now, I hate the thought of rebuilding the D 35 but I might have to.
bhunt is offline   Reply With Quote
Old January 21st, 2008, 10:53 AM   #2
jeeptjpaul
jeeptjpaul's Avatar
If you are not having any other symptoms or problems, I would guess it is just the Lock Right spinning a bit before it engages. The cross pin has to "spread" the lock right before the teeth mesh. Does everything else seem ok? No grinding, slipping, or whining from the rear?
jeeptjpaul is offline   Reply With Quote
Old January 21st, 2008, 01:27 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
X2
You're taking up the slack between the drive gear and pinion cross shaft.
Old January 21st, 2008, 03:18 PM   #4
bhunt
BigBri
bhunt's Avatar
Seems to work fine, no noises, locker works as good as the day I put it in. Start saving my pennies for the upgrade.
Thanks,
Page generated in 0.19012 seconds with 35 queries
