Dodge Truck Engine Basic Info - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 11th, 2005, 07:26 PM   #1
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Default Dodge Truck Engine Basic Info
Six Cylinders
-3.7L V6 2002-Present-
215 HP at 5200 RPM
235 lb-ft of torque at 4000 RPM
Cast Iron Block/Aluminum Heads
Overhead Cam
Bore X Stroke- 3.66 X 3.57
Compression- 9.1:1
-225 CID Slant-Six 1960-1991-
110 HP (2bbl Carb)
215 lb-ft of torque
Cast Iron Block & Heads
CIB (Cam in Block)
Bore X Stroke- 3.40 X 4.125
Compression- Varied
-3.9L V6 1987-2001-
175 HP at 4800 RPM (1997 Specs)
225 lb-ft of torque at 3200 RPM
Cast Iron Block and Heads
CIB
Bore X Stroke- 3.91 X 3.31
Compression- 9.1:1 (1997)
-5.9L I6 Cummins 199x-Present- (2006 Info)
325 HP @ 2900 RPM
610 lb-ft of torque @ 1600 RPM
CIB
Bore X Stroke- 4.02 X 4.72
Compression- 17.2:1
Eight Cylinders
-5.2L (318 CID) V8 1967-2001-
230 HP at 4400 RPM (2001 Specs)
300 lb-ft of torque at 3200 RPM
CIB
Compression- 9.1:1 (2001)
-5.9L (360 CID) V8 1971-2002-
245 HP at 4000 RPM (2001 Specs)
345 lb-ft of torque at 3200 RPM
CIB
Bore X Stroke- 4.00 X 3.58
Compression- 8.9:1 (2001)
-4.7L V8 1999-Present-
240 HP at 4800 RPM
Overhead Cam
Bore X Stroke- 3.66 X 3.40
Compression- 9.3:1
-5.7L V8 2003-Present-
345 HP @ 5400 RPM
375 lb-ft of torque at 4200 RPM
Bore X Stroke- 3.92 X 3.58
Compression- 9.6:1
Ten Cylinders
-8.0L V10 199x-2002-
310 HP @ 4000 RPM
450 lb-ft of torque at 2800 RPM
Bore X Stroke- 4.00 X 3.88
Compression- 8.6:1
Old December 5th, 2005, 10:49 PM   #2
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
Good Stuff
Spence1986 is offline   Reply With Quote
Old December 5th, 2005, 11:32 PM   #3
GreaseMonkey
Pew pew!
Yea, I still have to finish it. I hope to have more info for each individual engine, and I'm still missing a few engines.
Old February 4th, 2006, 01:05 AM   #4
GreaseMonkey
Pew pew!
Ok finished most of the basic info...will add more detailed info later as I collect more information. If you notice any mistakes, or want certain things added, let me know.
Page generated in 0.20096 seconds with 35 queries
