Jig for setting TJ brackets? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2008, 06:27 PM   #1
jthomp
jthomp's Avatar
Default Jig for setting TJ brackets?
How'd ya place your brackets on your axle properly? I just ordered brackets for the front (82 Waggoneer) from PORC (less than RE sells their own stuff for). I've never done any fab work like this but that's why I'm doing it, so any help/suggestions you have will be appreciated.
thanks JT
jthomp is offline   Reply With Quote
Old January 17th, 2008, 06:46 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
tape measure and a angle finder.
Old January 17th, 2008, 06:54 PM   #3
jthomp
jthomp's Avatar
I'm considering that, my concern is with the axle tubes being of different lengths, I wanna be sure I get it right cause I hate redoing things.
Old January 17th, 2008, 07:01 PM   #4
Jeepaholic
Jeepaholic's Avatar
You have to find the center of each axle and measure it from there.
If you want help I can swing over or you could bring the axle over here, I have done a couple of these :miff:
Old January 17th, 2008, 09:21 PM   #5
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
measure and copy your stock axle
Old January 17th, 2008, 09:55 PM   #6
Pre4runner
Bike Dude
Pre4runner's Avatar
I saw a cool trick where you take some bolts and stick them in the stock mounts, then take 1/4 rod and weld it to each, this makes sure all brackets are in the correct relation to one another then just center the jig you made and set your pinion angle
Page generated in 0.19759 seconds with 41 queries
