Something new for the outboarding crowd...... - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old January 17th, 2008, 12:10 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Something new for the outboarding crowd......
The Frame Outriggers came to be while searching for a good way, I ran into one of my competitors making something with the same idea but only done halfway. We finished the job and made them the way they should be made, made to last and take the abuse rock crawling can dish out. You can see how they are angled front and rear to avoid hanging up on rocks and how they are reinforced to take the pounding too!
These weld on both the side and bottom of the frame for greater strength and the end caps completely box the structure for maximum impact resistance. These would work equally well as lower link mounting positions on either the inside or the outside of the frame and thats why we make them both 4.5" x 4.5" & 7" x 4.5" long for the flat bottom surface. Also, being 1/4" thick helps a bit:D
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old January 2nd, 2009, 09:45 PM   #2
Gravel Maker
Steel Hauler
Default Another look at these is in order.....
These are getting to be the only way to go fullsize! Heres a pic of them thrown on a frame so you can better see how they work.....
Now you can get a better idea of how they can be used!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 6th, 2009, 06:40 PM   #3
itchy
itchy's Avatar
How much are these?
itchy is offline   Reply With Quote
Old January 6th, 2009, 06:51 PM   #4
Gravel Maker
Steel Hauler
Default They are $54 & $58 a pair.....
For the 4.5" & 7" lengths.....
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Thread Tools
Page generated in 0.27614 seconds with 35 queries
