Larger Industrial type air compressor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2008, 09:58 AM   #1
94lt1
Default Larger Industrial type air compressor
I have an air compressor I need to sell since it is 3 phase and I need a single phase for my garage. It is either a 60 or 80 gallon tank I am thinking 80 to be honest. It is a Speedaire by Dayton Direct Drive Model number 5Z044.
It is a 2 stage
3 phase
5 HP 60 HZ
2 cylinder
Oiler
I did know it worked before being disconnected and was the shops main compressor before my work bought it. They just never hooked it back up cause they had one already there and this was part of the company buy and equipment that came with it. I have no way to hook it up but was told by my production manager it was in working order when reomoved. It has been indoors for the last 3 years or so and has never been outside. Comes cutoff switch and 3 phase sub panel as well. Everything in the pictures are included (excluding the boxes around it! LOL!)
I will get more info when I get pics of the tags and that will have HP ratings ect.. on them. It was manufactured in 1989
I am looking for $750 O.B.O and would be great for a small shop.
Located in Monroe, MI
94lt1 is offline   Reply With Quote
Old January 20th, 2008, 08:42 AM   #2
94lt1
btt
Old January 20th, 2008, 08:45 AM   #3
curt1656
Praise the lowered
curt1656's Avatar
You can buy a phase converter and run it in you'rte own garage for about 150 bucks.
Old January 20th, 2008, 08:50 AM   #4
94lt1
Actually I would have to get at least a 10HP rotary phase converter for it to work properly (staitc converts although cheaper are not good for air compressors) and not burn the motor out and they are $800 for a good so I would rather see this go to someone who has 3 phase or a good rotary converter and spend the $ on a bit smaller one since I would not be needing something so heavy duty anyway (hind sight is 20/20). I don't want to throw more $ at it if I can avoid it.
Old January 20th, 2008, 08:55 AM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Just buy a 5hp single phase motor and put it on it. It will work just fine. Or I will trade you a vertical 80 gallon for your horizontal one. You would have to meet me in Ohio some where. Mine is a 3 lung 5HP Iron Man have had it for 10 years.
Old January 20th, 2008, 09:04 AM   #6
curt1656
Praise the lowered
curt1656's Avatar
I did the phase converter for a friend on a Bridgeport and a compressor he got for free, been working fine for the last 6 years.
Old January 29th, 2008, 07:33 AM   #7
94lt1
Well the problem with changing the motor is it is direct drive and I am not sure if they have direct replacements for a direct drive motor on this type of pump. They might but I really don't know.
Old February 25th, 2008, 07:40 AM   #8
94lt1
Will trade for a running Honda Odyssey Buggy. Doesn't matter year but looks like link below.
Old February 25th, 2008, 11:13 AM   #9
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
i have a 5 hp compessor, tree mill, and lathe and my 5hp converter runs all of them at the same time fine, i have converter plans if needed. hell you can make one with stroller wheel a drill and 3 phase motor . really works lol. or spend $120 at granger and build one like mine. you just filp switch..
samurai2240 is offline   Reply With Quote
Old February 26th, 2008, 10:48 AM   #10
94lt1
Will consider a good running snowmobile as well.
Old March 14th, 2008, 10:11 AM   #11
94lt1
btt
Page generated in 0.26150 seconds with 56 queries
