D60 kingpin H1 arms and cap print - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2008, 08:47 PM   #1
Bones
Bones's Avatar
Default D60 kingpin H1 arms and cap print
just reference stuff
search terms D60 dana 60 kingpin arm arms hi-steer high steer cap caps
For reference, the center of kingpin to tie rod hole in my situation was 7.5". THIS IS NOT STANDARD. The standard throw distance in most situations is 8". I used 7.5 becuase I am full hydro and wasn't sure if my cheap ram was going to have enough balls to create enough push through the full 8" stroke
For this style cap, the bottom will have to be beveled to clear the chamfer on the kingpin cap
If you want, you can mill a 10deg flat into the arm, so yout tie-rod or heim joint sits flat.
And what my very simple arm looks like.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.13741 seconds with 26 queries
