Geo -Spools, Lockers, or what? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2008, 05:52 PM   #1
Dirtdug
GreaseBall Extrordinar
Dirtdug's Avatar
Default Geo -Spools, Lockers, or what?
Geo, ......yes I am aware that it is not a Jeep. I have one of those as well and I am getting them both ready for spring! I am new to building up a rig though and looking for a little advice.
I am building up a fun woods rig, want to be able to have it safely roadable, and don't wish to sink too much doe into it. I have just installed 32" Super Mudders, 2" suspension lift, slight fender trimming, and installing a 2" body lift tonight. I have read up on "The Fozzy Alteration" to the Third Members gears where they weld in 4 places, but recommended for off road only. Is this what is done when people talk about a welded differential? I see one company that has developed a Front Locker but $400 is a bit more than I want to spend without careful consideration. If I ran a locker in the front could I use a spool in the rear and still have a good roadable machine?
And lastly should I toss the Sway Bars for improved articulation? If I do will it dangerously effect road safety?
I'm new here with more questions than answers and am happy to see such a helpful forum.
Any advise would be appreciated.
Thanks,
Doug
Dirtdug is offline   Reply With Quote
Old January 15th, 2008, 06:17 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
welding the diff means just that you weld the spiders gears to each other or to the diff case itself. not a good idea for something that would be road driven as you'll wear out tires and your handling characteristics will change drastically especially with it being such a short wheel base vehicle. i'm not familiar with the front axles in trackers but if they don't run any disconnecting system and the front axle is always turning a locker will also adversly affect turning, and handling. if you have lockout hubs like some trackers had then yes you can run a locker without any ill effects. for the sway bars don't simply toss them, best way is to find/buy/make your own disconnecting end links. they are simple to make and will allow you to retain on road handling and still have good articulation offroad.
Old January 15th, 2008, 06:52 PM   #3
scottie
Eye candy
scottie's Avatar
^ what he said ^
and there is also a Suzuki Section here.......
Old January 16th, 2008, 07:37 PM   #4
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Wait.......they have the Intraweb up in Rhodes? Next you'll tell me people in Bentley have it also:tonka:
Anyway neighbor, welcome to the board
Page generated in 0.17779 seconds with 35 queries
