Removing Gun blueing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2008, 01:35 AM   #1
FlatFender
Tap Tap Splat
FlatFender's Avatar
Default Removing Gun blueing
Ive got an OLD .22 that I need to re-blue. Now don't go all collector on me and say that the original finish should be kept, because this gun was neglected for a long time, and its rusted to the point that it NEEDS to be re-finished. I have lightly sanded off all the rust, but now it needs to be re-blued. Is there anything out there that will remove the old blueing from the gun short of sanding it all off?
Old January 15th, 2008, 01:37 AM   #2
bigcountrysg
Countryboy
bigcountrysg's Avatar
You can get a gun blueing kit from places like cabelas. In the kit will be a blueing remover. Just follow the directions with the kit and you should be good to go.
bigcountrysg is offline   Reply With Quote
Old January 15th, 2008, 08:09 AM   #3
mtnbikinbryno
mtnbikinbryno's Avatar
Send a message via AIM to mtnbikinbryno
Are you sure the inside of the barrel is OK? If it's shot you could always do what my buddy did. Pretty badass, I think. More money of course, but you'll only have to do it once.
From this...
To this..
Boyd’s barracuda stock
Green mountain 20” SS fluted .920” bull barrel w/match chamber
Power customs two stage trigger
Power customs recoil buffer
Power customs extended mag release
Bushnell 6-18x w/50mm objective
mtnbikinbryno is offline   Reply With Quote
Old January 15th, 2008, 09:03 AM   #4
FlamingTomato
You break it - You fix it
FlamingTomato's Avatar
Simple - no kit needed just some elbow grease
Use a scouring pad. The green kitchen type - it will remove the bluing - but will require some scrubbing.
steel wool will remove rust but not the bluing, so if its not that bad, you can polish the rust off, and get a re-blue kit to touch-up the spots.
FlamingTomato is offline   Reply With Quote
Old January 15th, 2008, 09:06 AM   #5
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
bore cleaner and some steel wool will remove the blueing. once removed use finer and finer steel wool to get the metal uniform and scratch free, then use the bluing kit. don't rush and it will come out very nice.
Page generated in 0.27571 seconds with 37 queries
