My sons S-10 mud bogger build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2008, 12:44 AM   #1
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
Default My sons S-10 mud bogger build
So I told my son for Christmas he was getting a bogger of his own
so this is our Farther/Son build
I forgot to take pictures before we started But it was a rusted Full size chevy. I got a 98 S-10 cab from PA few weeks back, has a new 4" rough country lift 3/4 ton axles (dana 60 sooner or later)
My Son David grining the rivits on the spring hangers so we can shorten the wheel base
Cheated and didn't feel like makeing all new mounts on a Bogger so I just used some 2x4 square tube and welded it the factory body mounts in the front then as all bogger cab get abused I used 1/4" plate above and below the floor to displace weight accross the floor so it wont fataige the metal and throught bolted it with 6" long grade 8 half inch bolt
Axle is moved forward here (108" wheel base)but not welded, I still need to cut the frame where it goes from 6" to 4 and bends up. so the finished frame will be strait and 6" the hole way, then
future plans are Built 350. 12.5 to 1 compression, steel crank, world sportman II heads, preditor carb...parts are here need to get the block machine work done, th 350 or 400 mated to a 205 depends on what I buy.. Still need to buy a front clip, and that will be comp cut forward and bunch of sheet metal work to make it look nice so it will damm near be a flat fender...rear mounted radiator and fuel cell, and a 8 point cage to keep him safe
more pics to come
scramblerman72 is offline   Reply With Quote
Old January 14th, 2008, 12:53 AM   #2
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Will you be my dad? Nice build can't wait to see more.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old January 14th, 2008, 07:08 AM   #3
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
YA sweet.. Keep the pics coming..
nick_n_ii is offline   Reply With Quote
Old January 14th, 2008, 07:17 AM   #4
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
x2
fukkinrizzo is offline   Reply With Quote
Old January 14th, 2008, 10:06 AM   #5
chevotass
chevotass's Avatar
lookin good so far. only thing id change is the dry straw bail next to you grinding and welding.. haha might wanna throw that outside
Old January 14th, 2008, 12:57 PM   #6
scramblerman72
Moonlight stomper
that was brought in from the horse barn for the new puppy (black spot on top laying on my grinder) to chil on and new barn chair...it has to stay, plus we were in the back of the rig not the front... and we havea hose and fire extiguisers in the barn all over, if it cought on fire it would be funny and laughed at...
it is a weekend project as my Son lives in waterford untill he grauduates this summer and only comes here on the weekend and I dont work on it with out him, its our farther/son project
Old January 14th, 2008, 01:00 PM   #7
tweak
Are we there yet?
tweak's Avatar
Nice project. Keep us updated!
Old January 16th, 2008, 08:10 PM   #8
88mudder
In the band!
awesome project
Old January 16th, 2008, 08:24 PM   #9
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
Nice dave... :P
he does great body work..my scout has proof!
fullthrottle is offline   Reply With Quote
Old January 16th, 2008, 08:42 PM   #10
jeeperbrian
GLFWDA member
that should be cool, are you looking to adopt?
Old January 16th, 2008, 09:42 PM   #11
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
looks good who truck next to it
roger is offline   Reply With Quote
Old January 16th, 2008, 10:33 PM   #12
montecarlo33
The Violator
montecarlo33's Avatar
Damn looks good. I grew up with the wrong dad..
My dad can't even change a set of wipers by himself.
Always loved the s-10's with fullsize frames...but only if done right! Which you are. Ive seen a LOT of trucks with stacked frames that look like hell.
Old January 17th, 2008, 01:14 AM   #13
scramblerman72
Moonlight stomper
My buddies, His barn also
Mine has another frame off resto I am painting for another friend, that is slow moving as we don't work on it much in teh last month...
To that S-10 I am building a 4 link front... I have allready cut the bed down 11 inches and going to comp-cut fender his fenders like I am doing to my son's. In fact it was Rob's Idea asking me if I could cut his fenders and make them look Good, what started out my remakeing the factory wheel well opening body lines to just a bit more at which I said I can make it how ever he wants..then we sat back with fine line tape and makeing out the opening to him takeing more and more out of the body to lower the truck down but still clear the 44" boggers.. so its getting comp cut in the front and wheel wells in teh rear getting streached open and raised big time just haven't desided on the shape yet
Old January 17th, 2008, 01:15 AM   #14
scramblerman72
Moonlight stomper
Nope 4 kids is enough and 3 of them aren't mine
Old January 27th, 2008, 01:52 AM   #15
scramblerman72
Moonlight stomper
Rear end with the curv cut out and new frame section grafted in so its all flat pull points and cross members made out of 2x6x.25 suported the frame with a 2x6 riped in half and welded in teh frame between the crossmembers...
the rear behind the back will be cut down more and flush mounted later on THe rear buckets Wont be used I will make new shackel mounts above it later so the spring is the lowest point so Rocks can't grap them
the Biggest Change is to save money I have now desided to stick my Scramblers 401 in his S-10 and buy him a set of 1 ton axles and 44's and later on build his Checy motor and reclaim my 401 when the Jeep lives one day
Old January 27th, 2008, 04:55 AM   #16
got mud ratt
Junk Yard Fab
got mud ratt's Avatar
Default bogger
project looks like its coming right along its cool to see father/son projects
got mud ratt is offline   Reply With Quote
Old January 27th, 2008, 09:03 AM   #17
roger
roger's Avatar
looks good keep up the good work
Old January 27th, 2008, 09:11 AM   #18
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
sweet project looks good
Bronco Ollie is offline   Reply With Quote
Old January 27th, 2008, 09:44 AM   #19
fukkinrizzo
looks good
Old January 28th, 2008, 12:07 PM   #20
scramblerman72
Moonlight stomper
this is just mock up as every thing will come back out and get painted, exspecily the motor it hasn't had paint on it for a while and the out side is starting to rust even sitting in the garage on the stand, I also need a good or new oil pan for it as it has my old pan with a JB weld trial fix from a rock bashing
Page generated in 0.83169 seconds with 83 queries
