UPROKTOY says it's impossible... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2008, 05:58 PM   #1
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Default UPROKTOY says it's impossible...
So Chad said that 17.5mpg in an '05 CTD was high so I decided to see what would happen if I drove it like a normal person.
I reset the meter and went on a 153 mile journey with a 500# snowmobile in the back for half the trip.
Here's the results...
This is a 2005 Dodge 2500 CTD/Auto/4x4 Long box crewcab with a Bully Dog Triple Dog with Outlook. I was driving in the towing mode which is the optimal fuel setting. Speeds were varied from 40-70mph and a few stops for in town traffic.
I can't assure it's 100% accurate but even assuming a maximum 15% error that still gives us over 17mpg.
Old January 13th, 2008, 05:59 PM   #2
steveo
In the band!
photoshop
Old January 13th, 2008, 06:00 PM   #3
scottie
Eye candy
scottie's Avatar
yeah, i get quite angry with diesel trucks, they can tow a shit load and get better mileage than i can.
Old January 13th, 2008, 06:06 PM   #4
brimy311
Smells like a Fork Liftis
brimy311's Avatar
That fuel meter lies more then UPRockToy. There is a reason ppl refer to them as the "lie-o-meter". Hand calculate it, you'll see, well unless you don't know Maff.
JcrOffroad.com
Like us on Faceook!
Old January 13th, 2008, 06:07 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Read.
http://www.pirate4x4.com/forum/showt...highlight=Fuel
JcrOffroad
Zoom Zoom!
Old January 13th, 2008, 06:19 PM   #6
clarkstoncracker
lol
clarkstoncracker's Avatar
Whats weird with my WJ, is the digital meter is actually under estimating my MPG.
Using the trip odometer vs gallons put in, I get around 18 mpg, where the digital meter says usually around 16 mpg. Thats a big difference.
Old January 13th, 2008, 06:35 PM   #7
Motor Slut
Motor Slut's Avatar
Originally Posted by Monkeyevil View Post
I don't want to buy Pirate4x4.
Old January 13th, 2008, 06:38 PM   #8
Motor Slut
Motor Slut's Avatar
It's a work truck and I don't drive it enough to calculate the mileage.
Old January 13th, 2008, 07:06 PM   #9
clarkstoncracker
lol
Why do people make a big deal about calculating mileage? If you always fill up the tank, its as simple as pushing in the trip button.
Old January 13th, 2008, 08:38 PM   #10
Two things here:
1) The fuel usage meters aren't very accurate, and are calibrated on the optimistic side. I'm rather curious about the bully dog setup... is that a piggy back? Know how they work, on a signal level? And how those signals are also used to calculate estimated fuel usage?
2) Most importantly, varied between 40-70, probably a 55-60 average, and I'm guessing in the UP... which means flat, straight, and very few stops.
I can completely see that mileage for that situation, unloaded truck (sled does nothing), those driving conditions.
For example, no matter the vehicle, when I visit my parents (180 mile round trip, completley flat very few stops, 55mph two lane roads, in the thumb), our vehicles get 20-30&#37; higher mileage than our normal mileage. Last trip there with my V10 dodge, I got 11.7mpg towing an 8500lb load (large tractor with loader, forks, other stuff), that be 8-9 mpg down here.
Old January 13th, 2008, 09:08 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I don't know how accurate those digital overhead calc. are. But I took a trip with Ironman in his old '04.5 Cummin dually w/4.10 gears. I looked at the over head a couple times and it said 22-23mpg. His truck had a some kinda chip, airfiler and exhaust if I remember correctly.
I'm sure that over stated what he was getting...but it must of been high teens at least.
Old January 13th, 2008, 09:21 PM   #12
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
In my experience I've found those fuel mileage calculators to be pretty accurate.
I swapped my truck with my Uncle's '05 Grand Cherokee a few years ago for a week to go down to Panama City Beach for spring break.
5 adults and loaded with luggage, we averaged 18 mpg round trip, including some driving around the area. I reset the fuel mileage gauge and the trip meter. We left with a full tank.
After all was said and done, the computer calculated 17.8 mpg, while the final math was 18 even. I'd say that's pretty accurate.
The same may not be true for all vehicles though.
Old January 13th, 2008, 09:26 PM   #13
Brods
The CTD BS meter accuracy varies widely in stock form. Best ever empty with stock ECM program was 19.8 mpg, overhead said 23.5 mpg. (the overhead was only reset at each fillup). Normal highway is around 18 so that 19.8 was probably a short fill up. Some have posted their overheads read lower than actual mpg. The only way to know is to check it over several tanks.
A Dodge tech posted this on another forum:
The ECM rcvs inputs from sensors,and knowing fuel pulse widths,Injector flow #s rpm,map tables etc computes the #s.There are no flow or fuel psi sensors involved.
It is simple to understand why a aftermarket box will screw up the mpg accuracy, the ECM simply does not know that the box has held the injector open longer or raised the rail pressure allowing more fuel to go into the engine, so the ECM thinks less fuel was injected and displays higher mpg than actual. When you have a performance box any hope for accuracy is gone.
Old January 13th, 2008, 09:36 PM   #14
scottie
Eye candy
scottie's Avatar
i've always found them to be pretty acurrate, but they've all been GM cars.
Old January 13th, 2008, 10:27 PM   #15
kickstand
circling the drain
kickstand's Avatar
Exactly.
My truck will average 25 mpg at 40-55 mph on a fairly flat stretch with no stop and go.
Get over 60 and I immediately drop to 18ish. get over 70 and I drop to 16
thats a gas truck, my point is that diesels WILL get great mileage in the 40-60mph range. I don't doubt 17 mpg at those speeds. but you will not get that mileage towing a load at 70 mph.
Old January 13th, 2008, 11:28 PM   #16
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
the best i ever got with a diesel was with my 85 f250 reg cab 2wd. i got 22mpg on a drive to lima ohio and back.
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old January 14th, 2008, 05:52 AM   #17
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
my 06 mega cab 4wd 3.73 gear auto averages an honest 20-21 at 70mph empty... and i do calculate it by hand... once over 70 it drops like a rock... it does have a programmer on it
Viperdave is offline   Reply With Quote
Old January 14th, 2008, 06:54 AM   #18
95geo
newbie
95geo's Avatar
they are not very accurate and also the fact that you have a tune in it makes it worse.
miles traveled/gallons to fill it up (after another fill)= actual mileage (after you factor in the correct rolliing diameter of your tires)
my DIC sometime reads 18 and I'll get 16, other times it'll say 22 and I'll get 17
if you would like Ill get a picture of my average at 99mpg, possible?
Old January 14th, 2008, 08:24 AM   #19
84Scrambler
The overhead lie-o-meter in my CTD has told me 22mpg before. Actual was 17. I hand calculate every tank. It isn't difficult or time consuming. I don't know why Dodge bothers putting those things in. They cost money and don't work. 20.3 probably equates to 16.5 in real life.
Old January 14th, 2008, 08:33 AM   #20
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Hand calculating only works if your tires are the right size for the gearing in your odometer.
Ford is notorious for undersizing the tire, which will roll the odometer up quicker and throw off the lie-o-meter.
That being said, I consistantly average 20+ with the powerstroke normal driving, and 17+ pulling either of my two rigs. (through my calculations:tonka:)
Page generated in 0.60180 seconds with 83 queries
