Dana 44 axle drop swap question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2008, 07:06 PM   #1
osweezea
Default Dana 44 axle drop swap question
I have a friend who is looking to swap a drivers side diff to a pass side diff by cutting the axle tube from inside the pumpkin to inside of the knuckle. Does anyone know if this is possible, and if it is, can anyone explain or send a link to us to show us how?
If it matters he has a 77 CJ5 and wants to swap in a 86 Grand wagoneer Dana 44.
Is it possible to just flip the axle so the drop would switch sides? Would we need to get reverse cut gears? Is that even a possibility? Any and all input is greatly appreciated. Thanks
osweezea is offline   Reply With Quote
Old January 12th, 2008, 07:15 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you can cut and weld the axle tubes to do whatever you want them to do, then just get new axles shafts to match. as for flipping the axles upside down. do not do this. you will starve the pinion bearings, because the R&P was designed to move the lubricant to the foward pinion bearing.
Old January 12th, 2008, 08:13 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Just buy a 79 or later grand waggy front (passenger drop already)
Old January 12th, 2008, 11:30 PM   #4
PavementPounder
PavementPounder's Avatar
Wow, someone's on crack tonight. He meant 79 or earlier for passenger drop.
And I agree. Retubing that axle is ridiculous from a cost & effort perspective, especially since it doesn't even have flat-top knuckles. Osweezea, tell your buddy he's on crack, also. I have the set of axles he really wants to have, but I also have a spare front housing and a couple Chevy shafts he can have cut down. Then all he has to do is swap the knuckles-out onto the 70's housing.
Let's stop the crazy talk about flipping axles over. The lubrication issue has nothing to do with it, as you wouldn't even get that far. The tires of an axle flipped upside down will spin in the opposite direction of the tires on the other end of the vehicle. You would go nowhere.
Reverse cut gears turn the same direction as any other gearset. That doesn't have anything to do with retubing, flipping stuff over, etc. He has a standard-cut differential and that's what type of gear he will always use in it, no matter what he does to it.
Old January 13th, 2008, 07:04 PM   #5
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
You can remove the axle tubes from the diff and knuckles and switch them from one side to the other. Just a lot of grinding and beating to get them apart and reattached. It won't be the easiest way but it can be done.
Old January 15th, 2008, 09:07 PM   #6
jeepers48
jeepers48's Avatar
iron moss has a front D44 from a NT waggy and its a passenger side drop if that helps. (parts forsale forum)
jeepers48 is offline   Reply With Quote
Old January 16th, 2008, 08:28 AM   #7
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Pm sent, I may be able to help??
RIP FULLSIZE4LIFE
Old January 16th, 2008, 10:11 AM   #8
fsumotorhead
N8KVB
fsumotorhead's Avatar
Don't know if you are interested, but i have a 10 bolt front out of a '87 3/4 burban, pass drop, complete from the knuckles inward.
Old January 17th, 2008, 05:19 PM   #9
osweezea
hey, thanks to all who posted! I'll let me buddy know whats out there, but if anyone else has anything that would work, feel free to add your input.
Page generated in 0.28966 seconds with 50 queries
