Chevy Dana 44 front - 6lug to 8lug? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2008, 06:25 PM   #1
montecarlo33
The Violator
montecarlo33's Avatar
Default Chevy Dana 44 front - 6lug to 8lug?
I have a 84 Chevy 1/2 with a dana 44 front and a 10 bolt rear, both 6 lug. I want to put a 14 bolt in the rear this season. Now I was told I could get a set of 8 lug spindles and replace the 6 lug spindles on it now. Is this true? What else in involved. I want to run the same lug pattern. Thanks.
Old January 11th, 2008, 06:55 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
yes, IIRC you will need hubs,rotors,caliper brackets? depending on if you have small or large bearing spindles you might need them also.
Old January 11th, 2008, 08:44 PM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
x2
i did it, not too hard
Old January 11th, 2008, 08:53 PM   #4
montecarlo33
The Violator
What doner axle do I want to look for? Only a DANA 44 8 lug?
Old January 11th, 2008, 09:37 PM   #5
Jeepaholic
Jeepaholic's Avatar
10 bolt or 44 parts will work, IIRC you should have a 10 bolt front, did you swap it?
Old January 11th, 2008, 10:47 PM   #6
montecarlo33
The Violator
No, I did not personally swap it, I was told it was a DANA44, but it may be a 10 bolt. I was just going by what the previous owner said. But then again he wasnt the brightest crayon in the box, he said the truck had a TH-350 trans, and I later found out it was a 700r4. I will have to check for myself. But its the same concept right, I will just need to find a 3/4 ton axle and swap out the hubs and caliper brackets? I already need new brakes so I will just buy ones for a 3/4 ton.
Old January 11th, 2008, 10:49 PM   #7
Jeepaholic
Jeepaholic's Avatar
ya either way the parts swap.
Old January 12th, 2008, 07:19 AM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you can find a 3/4 ton axle y not just put the whole axle in?
Old January 12th, 2008, 12:03 PM   #9
jeepfrk
jeepfrk's Avatar
I agree with this you will probly need to change the gears anyway
jeepfrk is offline   Reply With Quote
Old January 13th, 2008, 07:22 PM   #10
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Semi float 14 bolt
ttocsnekia is offline   Reply With Quote
Old January 16th, 2008, 08:55 PM   #11
montecarlo33
The Violator
Because I would like to do it a little cheaper if I could. I guess If I could find one for a good price, I would get it. I just assumed it would be easier and cheaper to swap the hubs instead of swaping the whole axle.
Old January 16th, 2008, 08:56 PM   #12
montecarlo33
The Violator
Originally Posted by ttocsnekia View Post
Semi float 14 bolt
Which one is better, Semi float, or Full float 14 bolt?
Old January 16th, 2008, 09:00 PM   #13
Jeepaholic
Jeepaholic's Avatar
Full float
Cheapest thing would be to get a complete one then you could sell yours complete.
Old January 16th, 2008, 09:34 PM   #14
montecarlo33
The Violator
Full float
Thanks, thats probely the route I will take then or at least try. Thanks for your help!
Old January 19th, 2008, 01:25 PM   #15
DodgeDude99
why bother, the only difference between a 3/4 ton front axle and a 1/2 ton front axle is the 8 lug outers. (and then the difference between a Dana 44 and a GM 10 bolt)
DodgeDude99 is offline   Reply With Quote
Old January 19th, 2008, 01:32 PM   #16
Jeepaholic
Jeepaholic's Avatar
Because the 1/2 ton is most likely a 3:?? gear and the 3/4 ton stuff is usually lower gear, easy to find 4:10 geared combo.
Old January 19th, 2008, 07:41 PM   #17
Ebrown
Ebrown's Avatar
here a line to CK5 but they did a Dana 44 not much different from the corp 10 bolt
http://coloradok5.com/8lugconversion.shtml
Ebrown is offline   Reply With Quote
Old January 19th, 2008, 11:41 PM   #18
DodgeDude99
true they do come with lower gears but it was just said axle, not axles.
Page generated in 0.54789 seconds with 77 queries
